i've seen my buddy do this same corner on w/ his ebrake going frigen fast in his 99 mustang (v6) and he has a manual it seems preptty like umm risky. well last night i was at a the same corner going 45ish and through the ebrake and decided that i was slowing down and my tires werent really slidding. so i went back at the same speed i pulled, twisted the wheel a bit more, punched it and drifted, let the ebrake off and kept on the gas to pull off the nicest drift with my front wheel drive, automatic volvo, un uprgraded that my buddy had ever seen (him being in the mustang at the intersection watching incase i came out bad). that was due to the fact it is a sort of y in the road with a small bridge after it. so he watched me do it around the origional corner and made sure their was no traffic when i blew the stop sign at the y to do a tighter corner. it was so nice i mean i was supprised. is there a way to improve this that anyones found? anyway ebrake line is bad now...
E-brake Cable Needs Tightening.
Started by a_place_08, May 14 2005 08:04 PM
9 replies to this topic
Posted 14 May 2005 - 08:04 PM
1995 volvo 850 turbo
--vacuum lines redone--hosetechniques.com universal kit
--open air filter intake--k&n flowcharger filter-custom hosing to ram air port
--optima red top remounted at 90degrees from origional position
--dist/rotor/spark plug& wires --ipd.com kit and bosch perfo. wires
PAC NW REPRESENTIN!!!!
Adam place
Blaine, WA 98230
Adam place
Blaine, WA 98230
Posted 14 May 2005 - 08:11 PM
QUOTE
The story belongs in racing
Please explain whats wrong with the E-brake? Are the cables broken, does it pull all the way to the top and not hold?
Posted 14 May 2005 - 08:14 PM
QUOTE(a_place_08 @ May 14 2005, 01:04 PM)
So, is the plan to destroy this car, then buy a new one? The emergency brake in 850s is probably not the same as the Mustang. The 850s have a seperate drum brake for the e-brake, so it doesn't use the main rear brakes. You are probably just going to trash your e-brake setup doing this, if you haven't already.
My other car has 4 wheel disc, but uses a lever on the rear calipers to manual operate the rear brakes for the e-brake. Using that setup the slide probably wouldn't damage the brakes, although it isn't something I would do.
ummm im pretty sure i post the EXACT question about 3 hours ago
....infortunatly i didnt provide a cool story to go with it
....any response as how to fix?
Edited by xcaliber912, 14 May 2005 - 08:16 PM.
Turbo lag was invented to let V8's think they had a chance!!
1995 850 Turbo -81K miles
Completed-
K&N Performance Filter
Joe P MBC-ZX
Chip by speedtuning (15 PSI)
AutoMeter Phantom in IPD pod
IPD strut brace
3in down pipe with E-cutout (open down pipe by mike "thelostartof")
Completed-
Joe P MBC-ZX
IPD strut brace
Posted 14 May 2005 - 08:16 PM
Actually you said whats wrong with yours, hes hasn't
I'll respond in your thread.
Posted 14 May 2005 - 08:17 PM
QUOTE(Bay13 Admin @ May 14 2005, 04:16 PM)
arent you the bestest
Completed-
Joe P MBC-ZX
IPD strut brace
Completed-
Joe P MBC-ZX
IPD strut brace
Posted 14 May 2005 - 08:20 PM
I like your bird.
Posted 14 May 2005 - 08:23 PM
QUOTE(Bay13 Admin @ May 14 2005, 04:20 PM)
im going there next year as a freshman. did you go there or just a fan of the Bball team?
Completed-
Joe P MBC-ZX
IPD strut brace
Completed-
Joe P MBC-ZX
IPD strut brace
Posted 14 May 2005 - 08:24 PM
neither it's just a nice colorfull avitar, stick out, and looks neet.
Posted 17 May 2005 - 04:18 PM
Get the haynes manual, it should help you fix it. Mine didnt snap or anything mine got pulled and stretched or something, so what i did was i released the ebrake, and on the rear brakes there is a sort of star nut thing, you can reach it with a screw driver, then all you do is click it up a few times. Anyway, c heck the haynes manual, if not im sure you can get it fixed for like 50 dollars
1993 Volvo 850 GLT 193,000mi
Back on the road Retired.
1997 850R 107,000
1997 850R 107,000
