I'm trying to remove the passenger side axle from my 1993 Volvo 850 5-speed.
From what I read, it should just "pull out". Is there a trick to this? a good place to pry? anything I could be missing? I have everything unbolted.
There's a little slot next to the transmission, but it doesn't seem deep enough to pry the axle out. Any information would be helpful!
thanks!
Terry
Axle Removal
Started by wisc_S70, May 14 2005 11:58 PM
Posted 14 May 2005 - 11:58 PM
1998 S70 t-5, 5 speed
1993 850 GLT, 5 speed
1981 242ti, 4 speed w/OD
Posted 15 May 2005 - 06:10 AM
Disconnect the axle from the hub, the big nut.
Disconnect the hub from the lower control arm.
Swing the hub / strut assembly away from the axle until it comes out.
Remove the axle carrier bearing support (it is bolted to the engine).
The axle will slide out of the transmission, there is no retainer ring.
Step childs92 Chevy Suburban and '03 Mini Cooper S
Step childs
Posted 16 May 2005 - 01:38 AM
Make sure you take this bracket off before you try ripping the axle out.
Posted 16 May 2005 - 06:42 PM
thanks for the help guys, I'll give it another go.
Terry
Terry
