Will Econ mode limit my top end or am i just seeing things, or did my car break?
Econo Vs. Sport Mode
Posted 16 May 2005 - 05:40 AM
'97 855 T5 - DEAD! '04 XC70 2.5T AWD - Current Whip
MY BLOG
I take wikd pics - Summit Photography
Posted 16 May 2005 - 01:34 PM
Posted 16 May 2005 - 01:45 PM
Posted 16 May 2005 - 04:04 PM
mines like that, allow the boost to build slowly and it will get to around 16, kickdown hard and you can get 18psi.
Volvo 850R Auto, 162K, Bobcat\SW Autos Custom Ecu, 18T, Reverse IC, 13 Row (Mocal Type) Engine Oil Cooler, 39 Row (3x 13 Row's)(Mocal Type) ATF Cooler, 20psi VDO Boost Gauge, Osram 50% Silverstars upfront, ITG Filter, OEM Strutbrace, Aerial Down Switch, 302mm Front Discs, Ferodo DS2500 Pads Front & Rear, Goodridge SS Brake Hoses, New Brake Hard Pipes, ATE Super Blue Brake Fluid, Koni Ajustables, Eibach pro kit, Slaters Link Rods, 4x Nankang NS-2 215/45/17 XL, Clear Side Repeaters, 70 Series Washer Jets, Powerflex Control Arm Bushes.
Fully Synthetic 5w-40 every 5K Miles, and flushed with 10l of Comma Dexron 3 ATF every other oil change.
In Progress: Custom Alu IC with 2.5" Core IC (Same Dimension as Stock one, Just thicker)
To Come: 3" Mandrel Bent down pipe and Cat Back.
Posted 16 May 2005 - 04:13 PM
make sure you read this guys signature before you start asking questions.
Posted 16 May 2005 - 04:54 PM
well, i meant that that "bobcat" is boostin 18, and has an 18T...
Posted 16 May 2005 - 05:57 PM
Posted 16 May 2005 - 06:08 PM
I'll have to beat on the car on the way home tonight to make sure she's still all good!
MY BLOG
Posted 16 May 2005 - 07:00 PM
No, the lights go out in all years for the 850. Don't know about the S70. The reason is you are manually shifting, although the shift points stay the same, it just won't shift above the gear you have selected.
If you shift into L from a stop, the car will remain in 1st in either mode. If you are rolling in sport and shift into L, it goes into 2nd. If you come to a stop and don't shift out, it stays in second. In Econ, if you shift into L at around 20 mph, it goes into second. If you slow down, it will shift into 1st and will surprise you if you aren't ready for it.
Posted 16 May 2005 - 10:31 PM
well i can actually get and hold 19 psi over 5000rpm, but this is again with a hard kickdown and shifting under full boost that causes a jump up to 19psi which holds untill i let off.
As im running a 15g map the ecu will limit boost to 17psi under normal driving, but it gets it under control at 19psi when i build boost fast. even tho im running a 15g map i have been told by my rica dealer that the fueling is good for 18/19psi (short duration). I have also tweaked the wastegate to give near similar spool up to my 15g.
once i have all my other mods done i will get a proper remap with some dyno time.
Edited by bobcat, 16 May 2005 - 10:32 PM.
Posted 17 May 2005 - 05:50 AM
So lemme get this straight - you bolted on a 19T on a 15G map and Rica told you it would be OK? You can't be serious.
Posted 17 May 2005 - 09:16 AM
no i have an 18t, which as we know is much easier to control than the 19t's.
the only danger with the 18t is running to much boost as in std form they spool slower than the 15g. I was told that I have the fueling for 18psi so as long as i dont exceed that i will be ok.
the car also has good stage zero (new o2,sparks,cap and rotor + upgraded cooling systems) which will reduce the chance of any missing etc.
Edited by bobcat, 17 May 2005 - 02:15 PM.
#14
Posted 17 May 2005 - 11:36 AM
the car also has good stage zero (new o2,sparks,cap and rotor + upgraded cooling systems) which will reduce the change of any missing etc.
That's cool. Nice score on the turbo - 18Ts are pretty hard to find from what I've seen.
#15
Posted 17 May 2005 - 02:14 PM
here in the uk a guy running a 19t with a 15g map has just had his engine let go! he was running 13.x 1/4 miles which may have been down un controlled boost etc.
so yes slater, its always better to have turbo and map the same.
