Friend's car has a loud knocking sound and shuttering that' s felt when turning..only when turning, and goes away after straighten. ANy thoughts?
Loud, Knocking, Shuttering When Turning
Started by 2005V70R, May 16 2005 03:27 PM
4 replies to this topic
Posted 16 May 2005 - 03:27 PM
2005 V70 R
1998 V70 GLT
"Took off the restrictor plate, gave the red dragon a little more juice"
1998 V70 GLT
Posted 16 May 2005 - 03:29 PM
tires could be rubbing.??
i have a GTI now
i will never forget the power of that R
Posted 16 May 2005 - 03:57 PM
probably cv joint.
Volvo 850R Auto, 162K, Bobcat\SW Autos Custom Ecu, 18T, Reverse IC, 13 Row (Mocal Type) Engine Oil Cooler, 39 Row (3x 13 Row's)(Mocal Type) ATF Cooler, 20psi VDO Boost Gauge, Osram 50% Silverstars upfront, ITG Filter, OEM Strutbrace, Aerial Down Switch, 302mm Front Discs, Ferodo DS2500 Pads Front & Rear, Goodridge SS Brake Hoses, New Brake Hard Pipes, ATE Super Blue Brake Fluid, Koni Ajustables, Eibach pro kit, Slaters Link Rods, 4x Nankang NS-2 215/45/17 XL, Clear Side Repeaters, 70 Series Washer Jets, Powerflex Control Arm Bushes.
Fully Synthetic 5w-40 every 5K Miles, and flushed with 10l of Comma Dexron 3 ATF every other oil change.
In Progress: Custom Alu IC with 2.5" Core IC (Same Dimension as Stock one, Just thicker)
To Come: 3" Mandrel Bent down pipe and Cat Back.
Posted 16 May 2005 - 07:34 PM
cv joint
Posted 17 May 2005 - 07:34 PM
Thanks fellas, I'll pass it on.
2005 V70 R
1998 V70 GLT
1998 V70 GLT
