Auto Tranny Sump Plug
5 replies to this topic
#1 bobcat
bobcat
  • 305 posts
Posted 16 May 2005 - 10:20 PM
as title says.
IPB ImageIPB ImageIPB Image
Volvo 850R Auto, 162K, Bobcat\SW Autos Custom Ecu, 18T, Reverse IC, 13 Row (Mocal Type) Engine Oil Cooler, 39 Row (3x 13 Row's)(Mocal Type) ATF Cooler, 20psi VDO Boost Gauge, Osram 50% Silverstars upfront, ITG Filter, OEM Strutbrace, Aerial Down Switch, 302mm Front Discs, Ferodo DS2500 Pads Front & Rear, Goodridge SS Brake Hoses, New Brake Hard Pipes, ATE Super Blue Brake Fluid, Koni Ajustables, Eibach pro kit, Slaters Link Rods, 4x Nankang NS-2 215/45/17 XL, Clear Side Repeaters, 70 Series Washer Jets, Powerflex Control Arm Bushes.
Fully Synthetic 5w-40 every 5K Miles, and flushed with 10l of Comma Dexron 3 ATF every other oil change.
In Progress: Custom Alu IC with 2.5" Core IC (Same Dimension as Stock one, Just thicker)
To Come: 3" Mandrel Bent down pipe and Cat Back.
#2 VolvoT5
VolvoT5
  • 717 posts
Posted 16 May 2005 - 10:26 PM
Part No: 6843113
Description: AW50-42LE Drain Plug
That the one?
#3 bobcat
bobcat
  • 305 posts
Posted 16 May 2005 - 10:35 PM
QUOTE(VolvoT5 @ May 16 2005, 11:26 PM)
Part No: 6843113
That the one?
thanks D, that was quick! any idea on the price?
#4 VolvoT5
VolvoT5
  • 717 posts
Posted 16 May 2005 - 10:39 PM
QUOTE(bobcat @ May 16 2005, 11:35 PM)
I was gonna ask why you need one of these?!
No idea on price, it will undoubtedly be cheap tho - the part is tiny.
You'll also need the gasket, pt number 977751
#5 bobcat
bobcat
  • 305 posts
Posted 16 May 2005 - 10:43 PM
QUOTE(VolvoT5 @ May 16 2005, 11:39 PM)
Thanks, i will make note of them and give volvo call tomorrow, also need to get some new grills (the little black ones next to the fog lights) to protect my new coolers as mine were broken.
p.s - can you get onto VOC forum?
#6 VolvoT5
VolvoT5
  • 717 posts
Posted 16 May 2005 - 10:48 PM
QUOTE(bobcat @ May 16 2005, 11:43 PM)
Left hand side grill is 6817834
Right hand side is split into two, due to the towing eye and part numbers are 9151306 and 9151305
No I can't access VOC, haven't been able to for 2 days, I hope that one hasn't gone the same way as the T5 forums!
