egtting the crankshaft seal done this week and have a couple of questions. Is this the same as the rms? Is there anything else that should be changed when the gearbox is out?
thanks,
Lenny
850 20 Valve Na Crankshaft Seal
Started by 850gltdub, May 17 2005 11:11 AM
Posted 17 May 2005 - 11:11 AM
Posted 17 May 2005 - 11:53 AM
QUOTE(850gltdub @ May 17 2005, 11:11 AM)
thanks,
Lenny
thanks,
Lenny
It sounds like the front crankshaft seal which means your tranny is not pulled. Might as well change the timing belt since it has to be removed anyway. Most often the rear crankshaft seal is referred to as the rear main seal. good luck
#3 Guest_Guest_*
Posted 17 May 2005 - 12:41 PM
QUOTE(campbell @ May 17 2005, 11:53 AM)
thanks!
