1994 850 non-turbo Back in Feb. I had an emergency(caliper was stuck causing left rear to smoke, needed to replace brake hose, caliper, rotor, and both pads) requiring my left rear caliper to be replaced by someone other than my reg. mechanic, my car is now being seen by my reg guy and he's telling me my rear brakes are screwed up causing the squealing after retrieving the receipt I find the guy who did my brakes used a rebuilt caliper and I was wondering if this could be the problem. I've never used the goodyear guy except to replace my tires and am kind of surprised with what I paid to find that he used rebuilt parts. I'm kind of curious is this a norm with this part or should I have been asked what I prefer.
Brakes
Started by
Guest_Guest_Francis_*_*
, May 17 2005 09:26 PM
4 replies to this topic
#1 Guest_Guest_Francis_*_*
Posted 17 May 2005 - 09:26 PM
Posted 17 May 2005 - 11:34 PM
QUOTE(Guest_Francis_* @ May 17 2005, 04:26 PM)
Most aftermarket brake pads squeak like crazy in the rear. The squeak is probably because of those, not because of the rebuilt caliper. Did your regular mechanic identify any problems apart from the squeaking?
'94 850 wagon, N/A, automatic, 170K.
Posted 17 May 2005 - 11:38 PM
QUOTE(Tom @ May 17 2005, 07:34 PM)
Yep...the problem probably lies in the pads ...the aftermarket calipers usually come loaded(meaning with pads) I would pull the pads out and add a factory set..still probably cheaper than a new unloaded caliper from Volvo?
"SMOKE TROUT NOT CRACK"
Posted 18 May 2005 - 01:11 AM
and to answer your other questions, using a rebuilt caliper is VERY common, just like a rebuilt axle.....
#5 Guest_Guest_Francis_*_*
Posted 18 May 2005 - 12:20 PM
QUOTE(prasamin @ May 18 2005, 01:11 AM)
He still has the car and wants to replace the pads so I gave him the ok, I'm just mad
