Service At 140,000 1997 850
19 replies to this topic
#1 KilgoreTrout
KilgoreTrout
  • 5 posts
Posted 13 June 2005 - 08:34 PM
I was wondering if someone knew what the typical service items would be at 140,000 on a 97 850. I believe the timing belt is on the list. What other items would be good to do at this time. Also, does the idler pully on the the timing belt need to be replace? I know this one has the hydralic type.
#2 theunderlord
theunderlord
  • PipPipPipPipPipPip
  • 14,738 posts
Posted 13 June 2005 - 08:43 PM
Turbo? NA?
#3 KilgoreTrout
KilgoreTrout
  • 5 posts
Posted 13 June 2005 - 09:01 PM
Its not a turbo but is a north american car if thats what you mean by NA.
QUOTE('98S70R @ Jun 13 2005, 01:43 PM)
Turbo?  NA?
Edited by KilgoreTrout, 13 June 2005 - 09:02 PM.
#4 theunderlord
theunderlord
  • 14,738 posts
Posted 13 June 2005 - 09:04 PM
QUOTE(KilgoreTrout @ Jun 13 2005, 02:01 PM)
No, i mean NA as in "naturally aspirated", you answered my question.
Has the car been serviced regularly?
#5 KilgoreTrout
KilgoreTrout
  • 5 posts
Posted 13 June 2005 - 09:18 PM
Yes it has been to the dealer every 10,000. I have been doing the oil changes between those visits. I was thinking of doing the timing belt on it this time after reading the process on bay13 and seeing the little alignment tool that IPD sells.
QUOTE('98S70R @ Jun 13 2005, 02:04 PM)
#6 grown azz kid
grown azz kid
  • 62 posts
Posted 13 June 2005 - 09:40 PM
At 140k I had:
timing belt
water pump
pullies
serpentine belt
tune-up (plugs and whatnot)
plus i needed front brakes & rotors and replaced a noisy power steering pump.
$2400 and one divorce later she runs like BFN!
GaK
1994 854 NA
Nothing in it that wasnt there when it rolled off the line
#7 KilgoreTrout
KilgoreTrout
  • 5 posts
Posted 13 June 2005 - 09:47 PM
QUOTE(grown azz kid @ Jun 13 2005, 02:40 PM)
At 140k I had:
timing belt
water pump
pullies
serpentine belt
GaK
So a waterpump is recommended too? I suppose if you are digging in to get the timing belt it might as well be replaced at that time.
#8 pwebb
pwebb
  • 707 posts
Posted 13 June 2005 - 09:50 PM
I had my serpintine and timing belt done, only to later have my water pump go. The coolant leaked onto the serp belt, and snapped it. excl.gif I would do it all while the mechanic has everything apart.
94 854 turbo - 160k - red on black
#9 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 13 June 2005 - 11:06 PM
Yes 140 is a T-belt and I would suggest a water pump as well maybe a tensioner pulley and a serp belt if needed. Thats really it wink.gif
"SMOKE TROUT NOT CRACK"
#10 Batalia
Batalia
  • 279 posts
Posted 14 June 2005 - 03:15 AM
75 dollars on ebay gets you a new water pump, gastket, and timing belt. I work at a parts store and I can't even beat that.
1968 122s
1995 850 Turbo
2004 xc70
Your Garage is not worthy
For the Masterpiece you built
That only looks like it cost a Fortune
While most flaunt their cars by going fast
You show off Standing Still
<img src="http://memimage.cardomain.net/member_images/6/web/162000-162999/162103_17.jpg" border="0" class="linked-sig-image" />
#11 Patrick.
Patrick.
  • 5,707 posts
Posted 14 June 2005 - 03:38 AM
I had previously understood that the water pumps are good well beyond 200k (Bosch)... was I led astray?
#12 IIIRpower
IIIRpower
  • 172 posts
Posted 14 June 2005 - 04:23 AM
QUOTE(KilgoreTrout @ Jun 13 2005, 05:01 PM)
ps sorry kilgoretrout,...i'm just playing....its alll good.
1995 T5-R yellow
k&n l kumho ecsta supra 712s on titans l upsolute chip l ipd catback l clear side markers
1995 850turbo white
k&n l avon tech m550s on 17" pegs l speedtuning chip l koni adjustables l h&r springs l samco l hightech silicone l 10% tint l denso iridiums l thule roof rack l valentine 1
#13 Guest_Guest_*
Guest_Guest_*
Posted 14 June 2005 - 04:01 PM
No problem. I found it funny myself.
QUOTE(IIIRpower @ Jun 14 2005, 04:23 AM)
#14 Gilhuly
Gilhuly
  • 1,506 posts
Posted 14 June 2005 - 08:40 PM
Do the water pump and don't stress over it. A failed water pump will not do anything to prolong the life of your engine.
I would think that a going through and cleaning out the PCV system would be an excellent exercise at 140k. How about dropping the oil pan and checking the oil pickup and gaskets in there? Simple things that increase the stress on an older motor in day to day driving.
#15 AirSquid
AirSquid
  • 12 posts
Posted 15 June 2005 - 07:57 PM
The manual spells it all out...I certainly wouldn't go dropping oil pan without good cause.
I would do:
T-belt (~$40)
Serp Belt(~$30)
T-belt tensioner(~$50)
Water pump(~$100)
Thermostat(~$10) You've already dumped coolant to replace pump....might as well and it's easy
New coolant(~$15)
New Spark Plugs ($30) (you probably need to take access cover off anyway...and it makes the timing belt work A TON easier when you have the plugs out to rotate the engine more freely)
Closely inspect the idler pulleys on timing belt and serp...replace if they spin like old roller skate wheels with no grease.
So you're out ~$250 bucks +/- and about 6 hours of work for a novice for a solid servicing for critical components and you get great piece-of-mind.
-Squid
Edited by AirSquid, 15 June 2005 - 07:57 PM.
#16 lightsandsirens
lightsandsirens
  • 175 posts
Posted 15 June 2005 - 08:09 PM
I am soon do for this as well, should the o2 sensor be replaced this time?
1998 S70 T5 Auto.
IPB Image
#17 AirSquid
AirSquid
  • 12 posts
Posted 23 June 2005 - 02:00 PM
I'm not a pro in this area...so I may get vetoed here, but...I would not replace O2 sensor. Generally, they are fairly easy to replace (no major disassembly reqd), AND the engine monitor is usually pretty good about detecting when they stuff (if the monitor is like other cars I've had), AND even if it does start to stuff, it won't strand you anywhere before you can repair it...it will just run poorly until you replace it. So, I'd wait till it dies. Anyone with more expertise on engine monitor may have more educated opinion on this...
-Squid
#18 AirSquid
AirSquid
  • 12 posts
Posted 23 June 2005 - 02:02 PM
nice sanitizer in the message board....harr harr..
in above:
stuff=stuff
#19 Guest_Guest_delav18_*_*
Posted 23 June 2005 - 03:55 PM
PCV system?
#20 theunderlord
theunderlord
  • 14,738 posts
Posted 23 June 2005 - 03:58 PM
QUOTE(Guest_delav18_* @ Jun 23 2005, 08:55 AM)
PCV system?
Positive Crankcase Ventilation
