My sense is that you would be happiest with a test drive on 17s and then sticking with a decent looking set of 16s, a rear sway bar from IPD. 17s are going to be a little stiffer than you're hoping for. If you do go w/ 17's, stick with new stock shock/strut combo from FCP Groton.
Upgrading Suspension Recommedations...
Started by seany, Jun 20 2005 04:56 PM
23 replies to this topic
#21
Posted 22 June 2005 - 02:56 AM
#22 Guest_Guest_seany_*_*
Posted 23 June 2005 - 08:45 PM
OK. Thanks Gents!
What I'm thinking is this:
1. Progressive-rate springs from Eibach. I want a bit of a lowered look.
2. Sway bar kit from IPD. I checked my 850...it has no rear sway bar!
3. End links. Should I get Quickbricks? Where do I find them?
4. Tires. I'm partial to Bridgestones, but my $$$$ can afford Kumho's. Can I get away with a 55 series tire (for ride) or do I need a 50 series to stop the rub?
So is the a good setup?
your thoughts....
your thoughts....
#23
Posted 23 June 2005 - 08:57 PM
QUOTE(Guest_seany_* @ Jun 23 2005, 01:45 PM)
PM user "SLATER" he's a kickass guy, we're lucky to have him on VS. He'll get ya hooked up bro.
#24
Posted 23 June 2005 - 09:57 PM
17" OZ Superlugerras 17 x 8
Toyo T1-S (Quite a decent tire, should be quite cheap since it is discontinued now)
H&R
Koni Yellows
OMP Struts
IPD Sways
