Scandinavian Import Servicenter
4 replies to this topic
#1 pmacca
pmacca
  • 47 posts
Posted 11 July 2005 - 03:21 PM
Scandinavian is good! Prices are good too. I also work with Phil and I would recommend you do the same!
1996 850 wagon 140K
1998 V70 GLT 65K
#2 Guest_Guest_*
Guest_Guest_*
Posted 07 November 2006 - 03:34 PM
Where are they located ?
#3 NEU
NEU
    Old Man Crew Photographer
  • 2,982 posts
Posted 17 September 2007 - 05:59 PM
AVOID THIS SHOP! EMAIL ME IF YOU NEED THE DETAILS!
These guys used to be good, they have been around for over 10 years, almost bought a car from them back then. After I got my V70R I took it to them put in a new bevel gear and trany flush, everything seemed good. Then when it was time to change the time belt water pump and belt tensioner I had them do that too. I'm not going to go into details but the problems I encountered from them were... Scratching the plastic engine cover on the R, I asked them to replace it. Stripping an oil return line banjo bolt, having to repair it with a helicoil, found metal shaving in the oil when I got it back. The alignment was off because of the oil line repair. And to ad insult to injury they scratched up the plastic engine cover AGAIN! it was brand new! All told the car was gone for a month! And I still had to shell out $50 bucks for an alinement. And then recently I discovered that when they flushed the trany they used the wrong fluid!
And do you know what there excuse was? Well we can't afford to pay to get the good mechanics. But they could afford a brand new place with new floors and offices and coffee makers but can't afford good help? He even gave me a sob store about how they had to fire the guy, like it my fauslt that he didn't know what the hell he was doing! And he is actually telling me this... I've never been so shocked at how stupid a Manager could be! After the second screw up I got them to give me $200 credit in labor for the future. But after the third screw up I said "Never" take it too them again.
This is a warning! Never go there!
NEUBAR
#4 stevemd
stevemd
  • 25 posts
Posted 27 September 2007 - 12:46 PM
I just don't know, guys sad.gif Good results 4 years ago. Mixed results last year. I have a 940t and the trans was leaking from the front. They pulled the trans to reseal the front (converter seal, front pump seal). They sent the front pump out to have the bushing replaced. They showed me internal housing gouges from some previous repair in VA (I guess). They said they couldn't guarantee the trans would leak after repair and sure enough it did start leaking again. I'm out about $900. for resealing the front of the trans and the pump bushing, sigh. Trans has always worked well, just leaks from the front rather badly.
#5 PhillxMartin
PhillxMartin
  • 35 posts
Posted 28 December 2007 - 05:09 AM
Peice of stuff company. Don't ever deal with these people they sold me wheels and tires that didn't even fit my car. I had to go back because it was rubbing so bad and they didn't offer me my refund.
