Strut Installation
5 replies to this topic
#1 pmacca
  • 47 posts
Posted 28 April 2004 - 06:45 PM
This past weekend I installed new struts and shocks on my 1996 850 wagon. Everything went smoothly and the results appeared fine. The next day I took it into a shop to get it aligned and after that I began to hear a clunking noise on the right side. It makes the noise mostly at low speeds and when I trun the steering wheel back and forth. I parked the car and pulled up the front end under the right wheel well and I could hear the clunk coming from the spring area. The spring appears to be seated fine in the strut and upper seat. I put new sping seats and strut mounts on the car too. Does anyone have any suggestions as to what might be casuing this problem. I know that it could have been something done during the alignment, but it really sounds like it is coming from the spring. Any suggestions or advise?
Thanks, Larry
1996 850 wagon 140K
1998 V70 GLT 65K
#2 XtremePsionic
  • 160 posts
Posted 28 April 2004 - 08:14 PM
check your sway bar end links. After my strut installation I've had continous trouble getting them to stop clunking. Getting new ones helped, but then the nut would be loose after a while.... Maybe Bay 13 can enlighten me the correct way to tighten the sway bar link nut.
If you still have troubles after tightening the swaybar link nuts you might have other problems like worn out links, worn out control arm, steering, tie rods... but try the swaybar link first.
1996 855, Koni struts, IPD strut brace, Bilstein HD shocks, IPD sway bars, 20% stiffer rear springs, 215/45/17 kumho asx on 17X7 16lb Team dynamics Pro race 1.
Visit my struts installation guide. http://members.shaw.ca/heeeeee/strut
#3 Volvo OD
  • 123 posts
Posted 29 April 2004 - 06:51 AM
The Haynes says to tighten to 37 ft-lbs, and I was told to hand tighten first, then torque down the end that attaches to the sway bar itself, then torque the nut on the strut.
1993 854GLT - 220,000KM, parked for the summer.
1984 BMW 318i - 500,000KM, Its not the brick, but its fun.
#4 pmacca
  • 47 posts
Posted 30 April 2004 - 05:29 PM
Thanks you guys for the advise. I tried to tighten up the sway bar links and could not. So, I took off the bolt re-positioned it and tightened it again. Whola! No more clunking!
Thanks again! Larry
1996 850 wagon 140K
1998 V70 GLT 65K
#5 jb7073
  • 647 posts
Posted 30 April 2004 - 05:47 PM
Yeah, sounds about right. When I installed my struts, found that I need new links on both sides. I'm probably ordering them next week. There goes $60, but hopefully will improve handling and lower noise.
'99 BMW 540i - 110k
'99 Volvo S70 AWD - 150k - Wife's
'93 940 - 220k+ - The Beast
'90 740t - 240k - gone
'97 850 T-5 - RIP 09/16/04 99,983mi
#6 Bay13
  • 6,378 posts
Posted 30 April 2004 - 10:33 PM
With The old link rods you could put a wrench in back to hold it while tightening the nut. The new one you can't so I use a set of needle noise vice grips to hold the assembly so the nut will bight and hold.
IPD
