Headlights Fell Off Their Posts...fix?
5 replies to this topic
#1 bostongmw
bostongmw
  • 85 posts
Posted 28 April 2004 - 09:15 PM
My headlights on my '96 850 are pointing straight down. It's obvious they fell of the three posts. I can not get them back on.
Anyone else have this happen (how!). Is there a trick to re-seating them?
1996 850 NA Sedan
90K Miles
Blue with tan cloth.
Rare Nordic package with no sunroof or leather.
~ Need a mesh grill and abs module ~
#2 Bay13
Bay13
  • 6,378 posts
Posted 29 April 2004 - 01:31 AM
Both sides at the same time, something is up, did you hit a big bump, did you try adjusting them? If nothing is broken you can get the reflector back connected to the adjusters but you will have to take the light apart. If you take off the back cover for the high beam light you can often see the ball and socket that works the verticial adjustment, I've managed to snap them back in place without taking the light out of the car.
#3 bostongmw
bostongmw
  • 85 posts
Posted 29 April 2004 - 04:27 PM
Both sides are indeed off. I'll revisit what you suggest. But my hands got pretty munched trying to re-seat them. They just do not want to get aligned and set on the posts no matter how much I force it. I feel kind of stupid since it looks so simple.
1996 850 NA Sedan
90K Miles
#4 Bay13
Bay13
  • 6,378 posts
Posted 29 April 2004 - 11:17 PM
Try turning the adjuster to move the ball part into a better position to get it to catch, last resort is take the headlight out of the car and take the glass off the front and try it that way. With the glass off keep everything off the reflector, don't clean it or anything, it will end up messed up.
#5 850 Stylzz
850 Stylzz
  • 447 posts
Posted 30 April 2004 - 02:39 PM
Definitely try messing with the adjusters (specifically the up/down one) before your next try. I had a sort of similar problem. Thought I was never going ot get the thing back on. But after deciding to point the light all the way down (ie. making the top adjuster move forward) it became much easier to snap on.
I hope that made some sense.
1995 850 GLT
Stage -1
General Competence -2
#6 bostongmw
bostongmw
  • 85 posts
Posted 30 April 2004 - 05:23 PM
Ok - I see what you mean. I'll try it that way and with the glass off. Happy to see someone had the same issue re-seating it. It just seems so obvious but its a bugger.
1996 850 NA Sedan
90K Miles
