Alright, my driver side heated seat is not working. I checked the fuse, its fine. I also noticed that the light on the switch does not work, i dont know if this is related. I have no idea where to start looking to solve this problem. Any help would be appretiated.
Heated Seat Not Working...
Started by 850_Turbo, Sep 25 2005 12:10 AM
Posted 25 September 2005 - 12:10 AM
'94 855 Turbo
175k miles and counting
IPD overload Springs, Bilstein HD shocks, K&N panell filter, Koni Sport struts w/ stock springs
#2 Guest_digital_*
Posted 25 September 2005 - 02:58 AM
I dun have heated seat.......
logically if I had heated seat.
Check fuse first, if fuse ok
then
look under the seat check for wiring into the seat.....
disconnect connector and use ohmmeter / resistance meter to check heater continuity. that will tell u if heater need to be replaced
if heater ok
it is the wiring or relay..........in such case since I dun have heater u need to ask someone else
ps. (I only have the empty connector under my seat so I know its there
then
if heater ok
Posted 25 September 2005 - 10:09 PM
Maybe it just takes a while for the heater to warm up. Last winter mine could take 30 min before becoming noticably warm. Most of the time it tool 30 min, sometimes it would heat within 10 min.
1998 Volvo V70 R
Posted 25 September 2005 - 11:12 PM
On my 98 S70 how the seat heaters work is tied to the air temp.Must be a sensor somewhere in the system
Black 98 S70 na
