Weirdest S80 Problem Yet....
Started by
Guest_Guest_keefus_*
, May 03 2004 12:48 PM
12 replies to this topic
#1 Guest_Guest_keefus_*
Posted 03 May 2004 - 12:48 PM
I have a 1999 S80 T6 w/88k miles. I have noticed this phenomenon at least six or seven times now, so I know it's not my imagination or a fluke. The most recent time was last Tuesday.
Whenever I am sitting at a light in drive waiting for the signal to cycle, and a large deisel-powered vehicle (truck, bus, etc.) is idling within 10 or 15 feet of my car, my idle starts to fluctuate, nearly in perfect synch with that inherent fluctuation that most idling deisels have. I know deisel engines don't have spark plugs or high-energy ignition systems, so it isn't likely some sort of RF interference. In every case, the vibration from the deisel could be felt inside my car.
I was wondering if anyone else has seen or heard of this. I know if I mention it to the dealer service department, they will think I'm an even bigger kook than they think I am now. I can just imagine them rolling on the floor laughing at me. Any answers/theories/well-crafted thoughts would be appreciated.
keefus
Richmond, VA
1999 S80 T6, 88k miles; 2001 V70XC, 82k miles (wifemobile)
keefus
Richmond, VA
Posted 03 May 2004 - 07:48 PM
Are you sure the car is actually fluctuating and its not perhaps the bus noise resonating through the car or somethign of the like? I don't know, but perhaps the tachometer is sensitive to noise or something, it's definitely pretty odd.
Also - Glad to see another Richmond-er! Hang around man, got to join up for the meets and things. =D
-Andy
-Andy
1998 V70XC
1994 850T
1994 850 NA 5spd
1994 850T
1994 850 NA 5spd
Posted 03 May 2004 - 08:08 PM
I have noticed something similar. There is an oscillation, but the idle speed itself is not affected. However, whenever it happens I tend to look at all my guages to make sure nothing is amiss.
If it is what is happening to me, then it may be oscillations due to the difference in frequency of your engine and the deisel engine or a muscle car - both of which have a low frequency "note" from the exhaust.
When tunning a guitar one of the things to listen for is the oscillations of sound. When there is no oscillation, the two strings are in tune. Slow oscillations means that they are almost in tune. Fast oscillations means that they are not close to being in tune. This is all relative - the frequencies have to be similar to each other else the oscillations are not apparent, which may be way it is evident only around diesels.
Next time this happens, try gently increasing your RPM and see if the frequency of oscillations is altered.
Edited by aikitect, 03 May 2004 - 08:10 PM.
2000 V70R
Venetian Red
Upsolute Chip
Venetian Red
Upsolute Chip
#4 Guest_Guest_PyroTech_*
Posted 03 May 2004 - 08:48 PM
have no idea about your problem but it always makes me think there is something wrong with my car when there is a ricer with big exhuast in my blind spot and my car starts to hum and vibrate. I dont see the car and starting check to see if something just went wrong with my car.
Posted 04 May 2004 - 12:03 AM
Dirty throttle unit.
1996 854 Turbo
BSR catback
Speedtuning Chip- 15psi
Reverse intercooler piping
K&N drop in
NGK Iridium plugs
Dakota Digital Boost/vac gauge
...And now my car's wicked fast!!
BSR catback
K&N drop in
NGK Iridium plugs
Posted 04 May 2004 - 01:45 PM
The eletronic throttle body might have a problem with shielding? That's bizzare.
1998 V70 T5 / 2000 BMW 328i 5spd
Posted 04 May 2004 - 06:52 PM
my guess would just be that they are matching the resonant frequency of your car. I dont find that at all implausible. However, I have never experienced it, so that must be taken with a grain of salt.
1995 850 GLT
Stage -1
General Competence -2
Stage -1
#8 Guest_Guest_keefus_*
Posted 04 May 2004 - 10:25 PM
There is an actual fluctuation of the idle. I can feel it, and the tach bounces!
I have a relatively new ETM, and I removed it and cleaned it about a month ago as part of my general spring maintenance (new Volvo plugs, clean ETM, new air filter, etc.).
All I can think of is that there is some kind of vibrational frequency or resonance that the ECU or ETM are sensitive to. Diesels should not emit any kind of RF energy, or similar, because they don't have coils/plugs/etc. I know vibrational resonance can affect computers, but I would have thought that the ECU was pretty well damped. Maybe the vibration goofs up the ETM??? Who knows...this is very weird, and I know I am not just imagining it.
keefus
keefus
#9 Guest_Guest_keefus_*
Posted 05 May 2004 - 02:10 PM
Rich, Do you have any thoughts/theories on this???
keefus
keefus
Posted 05 May 2004 - 09:24 PM
Next time it happens, turn your a/c off. I have found that the T60 has a noticeable resonance from the exhast at idle but only as the a/c cycles on (which also explains your rpm fluctuations)
Posted 05 May 2004 - 10:19 PM
Does your throttle unit have a yellow or white sticker on it? If the sticker is white I would suspect the throttle unit is the problem. All the new ETM's have yellow stickers.
1996 854 Turbo
BSR catback
K&N drop in
NGK Iridium plugs
BSR catback
K&N drop in
NGK Iridium plugs
#12 Guest_Guest_keefus_*
Posted 07 May 2004 - 03:48 PM
I have a yellow sticker on mine. The dealer replaced my ETM three different times (thank God for the warranty...) before they realized that it was a bad relay, and not the ETM itself.
Posted 07 May 2004 - 05:06 PM
I'm curious about this, I read your post. (I'm a physicist, so this is the sort of thing I like) One, next time it happens, try turning off your A/C, and then increasing your revs. I'm not sure those will help, but might as well test both of those hypotheses. My first guess is that the vibration may be a resonant mode of your tach (there are springs and the like in those, usually). However, you said you can feel the idle changing, which may rule that out (another reason to turn off the AC, isolation of variables). Another possibility is that moving an electronic part will cause small pertibations on the electronic signal ("signal noise", essentially), and it's potentially possible that the outside vibration is inducing an oscillitory cycle that creates increased signal noise in your electronic management unit. Is the behaviour you observer periodic or aperiodic (ie, is it even timed, is it "random", is there a discrenible pattern in the oscillation?).
[edit: I don't mean it to read like "there's a chance moving electronics create signal noise". Moving electronics does cause signal noise, the possibility is that there's either louder noise or some sort of periodic noise affecting your engine management system.]
Edited by jross, 07 May 2004 - 05:08 PM.
