Where To Put The Foor Jack?
16 replies to this topic
#1 jleilich
jleilich
  • 112 posts
Posted 05 October 2005 - 06:41 PM
This may have been asked before, i looked and couldnt find anything on it.
I have a 2000 s80, The manual only mentions the factory jack for jacking up the car. I cannot find a place to put my floor jack on it to jack it up, or where to place jack stands without damaging the under side of the car.
can somone help me out. Maybe an adapter for my floor jack to go on the factory jack mount??
Black 2000 Volvo S80 T6 (my driver)
1970 plymouth Cuda 440 ,11.64 116mph (my hotrod)
2005 Dodge Ram Quad Cab Hemi 4x4 (The Truck)
1956 Ford Fairlane Club Sedan 2dr (project car)
#2 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 05 October 2005 - 07:39 PM
QUOTE(jleilich @ Oct 5 2005, 11:41 AM) View Post
put the floor jack where the gfactory jack woud go...
#3 Guest_Guest_*
Guest_Guest_*
Posted 06 October 2005 - 11:58 AM
The factory jack has a small hook like thing that goes into a bracket that is attached to the car. The floor jack is flat. If i try to put the floor jack on that thing it will damage my car.
#4 Kibim
Kibim
  • 2,319 posts
Posted 06 October 2005 - 12:04 PM
I always put my floor-jacks under the wish-bone mountings on the frame. Works fine.
#5 V Tuning 850
V Tuning 850
    BIG TIME TOOL
  • PipPipPipPip
  • 3,624 posts
Posted 06 October 2005 - 12:29 PM
Somewhere on the frame near the edge of the car. That is where somone has always jacked mine up.
#6 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 06 October 2005 - 03:19 PM
QUOTE(Guest @ Oct 6 2005, 04:58 AM) View Post
no it won't... i pick up my car all the time by doing that exact same thing....
#7 Kibim
Kibim
  • 2,319 posts
Posted 06 October 2005 - 03:26 PM
Doesn't help much if you wanna pick it up straight...
To be honest, when i need to get under my car, i take it to a friend's garage, and pull it up on a drive-on hoist. Safer, easier, and far less physical!
#8 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 06 October 2005 - 03:27 PM
QUOTE(Kibim @ Oct 6 2005, 08:26 AM) View Post
Well, I'm just picking it up to either, 1) change rims or 2) get the car up on jackstands... not to hold it up there for any length of time.
#9 gr8gatzby
gr8gatzby
  • 1,349 posts
Posted 06 October 2005 - 03:39 PM
QUOTE(VS Underlord @ Oct 6 2005, 11:27 AM) View Post
i wonder if anyone makes a garage ceiling mounted winchlike device that will raise a car via straps/cables that hook at 4 corners of the vehicle....
Volvo n00b in training
2000 V70 XC SE AWD Wagon
95 850 NA
Volvo: The safest car to die in...
About Me & My Design
#10 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 06 October 2005 - 03:46 PM
QUOTE(gr8gatzby @ Oct 6 2005, 08:39 AM) View Post
I have a 6 ton Bridge Crane that would might work.
#11 gr8gatzby
gr8gatzby
  • 1,349 posts
Posted 06 October 2005 - 04:13 PM
QUOTE(VS Underlord @ Oct 6 2005, 11:46 AM) View Post
do you rent by the hour or by the day?
95 850 NA
#12 bottlecap
bottlecap
  • 333 posts
Posted 06 October 2005 - 04:50 PM
to put rims on just use the stock jacking points and do one side, then the other. for most front end jobs you can use part of the sub frame. stuff in the back is a little harder, but you shouldn't find yourself back there too often.
-mike
'95 854 T5 with >170k
#13 Guest_Guest_*
Guest_Guest_*
Posted 11 October 2005 - 06:02 PM
im not just putting rims on. Im talking about bleeding the brakes, i dont want to just use that crappy jack that will fall over and kill me or land on my leg.
#14 Hagan
Hagan
  • 417 posts
Posted 11 October 2005 - 06:19 PM
QUOTE(Kibim @ Oct 6 2005, 08:04 AM) View Post
I do the same and place the jackstands running parrallel to the frame just past the factory jack points on either side. If you really can't find a place for the stands, jack it up and start tapping the underside of the car in places you think you might be able to put the stands. The place with the highest pitch or "tightest" sound is probably best.
'96 855 Turbo Red
IPD sway bars, IPD springs, Koni front, Bilstein rear, K&N panel, VDO boost guage, OMP strut brace, Dawes dual stage MBC, QBM sway bar links
#15 Slater
Slater
    Quickbrick Motorsports
  • 3,198 posts
Posted 11 October 2005 - 09:14 PM
Just put it up on blocks. That's how we do it old skool downtown.
Edited by Slater, 11 October 2005 - 09:15 PM.
#16 Guest_Guest_*
Guest_Guest_*
Posted 09 October 2006 - 02:15 PM
If your going to jack the car up using the proper jack locations (by the driver/passenger doors), what are the correct locations to place 4 jack stands under the car?
I havent tried it, but I get the feeling that the jack stands I just bought are too high(even at lowest height) to slide under the car when using the side jack locations and the volvo jack. Any recommendations?
thanks
#17 nervegrind3r
nervegrind3r
  • 70 posts
Posted 13 October 2006 - 08:33 PM
can anyone tell me where the proper points are to put the car on 4 jackstands, or where to jack the car if not jacking from the side points near the doors?
thanks
'02 S60 NA
