no codes are set. there is an obvious lag in performance at low rpm's. the car even sputters and jerks until about 3500. after not starting for a few days, while revving the engine just after start, thin white smoke comes out the tail. i thought about the following replacements, but can't afford them all. its a 94 n/a 850 with about 92000 miles.
airbox thermostat
knock sensors
oxygen sensors
catalytic converter
could someone please explain what symptoms might be of each of these being faulty? who knows, the culprit may not even be anywhere near where i'm looking, but hey, what the monkey, right?
What Should I Replace?
Started by Patrick Dickens, May 05 2004 08:19 AM
6 replies to this topic
Posted 05 May 2004 - 08:19 AM
Posted 05 May 2004 - 10:25 AM
Try an Italian tune up including the cap and rotor and wires.
Posted 07 May 2004 - 05:31 AM
Tried that. Someone on Brickboard suggested a leaky head gasket. Could this be it?
Posted 07 May 2004 - 02:53 PM
Have you tried a can of BGK44 in the fuel tank?
John, Sarasota, FL
'01 V70 T5, '07 S60 2.5T
Posted 07 May 2004 - 03:32 PM
the head shouln't leak if the engine hasn't been over heated
Posted 07 May 2004 - 07:55 PM
Ok, I've ruled out the head. What's BGK44?
What might some symptoms be of faulty:
airbox thermostat
knock sensors
oxygen sensors
catalytic converter
leak on vacuum tree
airbox thermostat
knock sensors
oxygen sensors
catalytic converter
leak on vacuum tree
Edited by Patrick Dickens, 08 May 2004 - 08:18 PM.
Posted 09 May 2004 - 05:31 PM
QUOTE(Patrick Dickens @ May 7 2004, 01:55 PM)
airbox thermostat
knock sensors
oxygen sensors
catalytic converter
leak on vacuum tree
airbox thermostat
knock sensors
oxygen sensors
catalytic converter
leak on vacuum tree
Maybe the MAF?
Search for the username Chopper along with MAF. Seems like he's replaced his fair share of those.
Not sure of the symptoms though.
'99 BMW 540i - 110k
'99 Volvo S70 AWD - 150k - Wife's
'93 940 - 220k+ - The Beast
'90 740t - 240k - gone
'97 850 T-5 - RIP 09/16/04 99,983mi
