My daughter tells me her car is a mess, shakes a lot, black smoke from the tail pipe, severe loss of power and flashing check engine light to boot.
I was able to isolate the problem to #2 cyl. Plugs looked clean but I installed a new set of Volvo plugs I had for my wife's 98 V70.
Problem got worse. #2 Cyl is no longer alive now. I can hear the injector clicking normally so I borrowed the ignition wires and dist. cap from my wife's 98 V70 (this happens to be my diagnostic tool)
All my problems went away.
Upon closer inspection I found a hole in the plastic insulation of the ignition wire at the point where the top of the spark plug would sit. The spark burned a hole right through the insulation.
Is this helps somebody else, you may save yourself some headache.
Severe Misfire, Loss Of Power, Flashing Cel
Started by Vitor, May 06 2004 04:20 AM
1 reply to this topic
Posted 06 May 2004 - 04:20 AM
Step childs92 Chevy Suburban and '03 Mini Cooper S
Step childs
Posted 06 May 2004 - 09:47 AM
Good find.
The cap, rotor, and wires are not called out to be replaced on any maintenance schecule. I've found that 50-60K for the cap and rotor and 100K on the wires, help to keep those weird problems that can show up from happening.
