Vms Fuel Pressure Regulator
33 replies to this topic
#1 TorqueSteer
TorqueSteer
    Pretty Boy Racing
  • 4,231 posts
Posted 24 December 2005 - 03:16 AM
Im looking into ordering the VMS FPR http://www.volvomoto...04d5cac5f071e5a
Im hoping that being able to play with the fuel pressure will allow me to lean my mixture a bit, as im running low 11's in the AFR even at 20 pounds of boost on the speedtuning chip. Just wondering what your guys thoughts are about their new product.
#2 Slater
Slater
    Quickbrick Motorsports
  • 3,198 posts
Posted 24 December 2005 - 03:37 AM
FPR is about the crudest way to control fuel, and is not precise at all. ECU tuning is obviously the best way. For the cost of a decent FPR you can get a remap that will be able to maintain a perfect AR across your entire powerband, not a hit or miss solution.
#3 850drag
850drag
  • 1,353 posts
Posted 24 December 2005 - 03:56 AM
QUOTE(TorqueSteer @ Dec 23 2005, 07:16 PM) View Post
I am currently running a 4 bar fuel pressure regulator and Let me tell you I am running so rich you can smell it on the plugs. Mine however is not adjustable. I wish I would have gone adjustable. It would have made life alot easier. We are sending one of these to Michiel Nouwens for his vms motor which should help him get the fine fuel to air ratio that can help him out with his 500+hp project.
Visit My s40 Website
2007 S40 T5 AWD
Volvo tech in Portland Oregon
#4 BlackT5
BlackT5
    NWC Rod Bender
  • 6,130 posts
Posted 24 December 2005 - 07:07 AM
so it's a rising rate FPR?
1998 S70 T5M - Project BlackT5                                          1999 XC70 - Rebuilding or parting.
2000 V70R - B5234T3 & M66 swapped                              2005 S60R - Rebuilding or parting
1998 V70R- M58 swap cancelled.. sold                              2000 Hyundai Accent - Fuel saver
1998 XC70 - Sold        1994 Ford Exploder - Winter beater
#5 Oele
Oele
  • 64 posts
Posted 24 December 2005 - 01:02 PM
QUOTE(850drag @ Dec 24 2005, 04:56 AM) View Post
Thank Aaron,
This weekend I am swapping engines in my 2 T5's... ;-)
Very very exiting...
Stock on the outside..
#6 TorqueSteer
TorqueSteer
    Pretty Boy Racing
  • 4,231 posts
Posted 24 December 2005 - 01:24 PM
QUOTE(Slater @ Dec 23 2005, 10:37 PM) View Post
I hoping to go to the Civinco Engine Management in the near future if all goes well, so im looking for a temporary solution to play around with while I have the speedtuning ecu.
#7 850drag
850drag
  • 1,353 posts
Posted 24 December 2005 - 03:21 PM
QUOTE(BlackT5 @ Dec 23 2005, 11:07 PM) View Post
it is a fully adjustable up to 85psi with the tubing ect to mount it any where you want.
QUOTE(TorqueSteer @ Dec 24 2005, 05:24 AM) View Post
Oh and I forgot to tell I had a stock ecu. so you could use it with your ecu you have know wiht no problem.
QUOTE(Michiel Nouwens @ Dec 24 2005, 05:02 AM) View Post
Thank Aaron,
Good luck, if you have any questions about anything Gives us a call or pm me.
2007 S40 T5 AWD
#8 BlackT5
BlackT5
    NWC Rod Bender
  • 6,130 posts
Posted 24 December 2005 - 05:02 PM
is it rising rate or linear?
#9 850drag
850drag
  • 1,353 posts
Posted 24 December 2005 - 08:29 PM
QUOTE(BlackT5 @ Dec 24 2005, 09:02 AM) View Post
I think its rising, But I will have to double check.
2007 S40 T5 AWD
#10 Johann
  • 5,153 posts
Posted 24 December 2005 - 10:13 PM
Same thing, non custom VMS color..
#11 VolvoWill
VolvoWill
  • 529 posts
Posted 24 December 2005 - 10:38 PM
I am going to be adjusting my fuel with an Apexi SAFCII. I have the Innovative motorsports wideband.
#12 TorqueSteer
TorqueSteer
    Pretty Boy Racing
  • 4,231 posts
Posted 24 December 2005 - 10:54 PM
QUOTE(VolvoWill @ Dec 24 2005, 05:38 PM) View Post
#13 VolvoWill
VolvoWill
  • 529 posts
Posted 25 December 2005 - 12:16 AM
#14 ccsct203
ccsct203
  • 174 posts
Posted 25 December 2005 - 01:41 AM
I would say not to waste your money or time.
I installed a RRFPR and I find that the O2 sensor will send a rich or a lean signal to the ECU and the ECU will just adjust to keep the air fuel ratio around 14.7:1.
I found that it's very quick learning too, in a matter of seconds.
I'm working on a way to adjust the ratio in a novel way. At a preset MAF output voltage, disconnect the O2 sensor and the "limp home mode" should be richer then you would want. To adjust the rich condition I will next feed the MAF input to ECU as a lower false input. If this false voltage is adjusted based on a custom map, then the ECU will give the required results.
I have the circuit drawn out just waiting on some electronics. I should have it running within a month.
1998 V70R, Black, K & N drop-in, E-codes, clear corners, Poly top mount, Strut bar, Konis, rear IPD sway bar, 302mm Zimmerman, Mangels, Front IPD sway, Snow Performance Injection unit,
#15 Slater
Slater
  • 3,198 posts
Posted 26 December 2005 - 01:52 PM
QUOTE(850drag @ Dec 23 2005, 10:56 PM) View Post
You don't have the "typical" setup. 95% of the people asking about this upgrade have a relatively stock engine with minor mods and a chip. For them the FPR is a waste.
#16 550
550
    someone please talk to me
  • 12,852 posts
Posted 26 December 2005 - 03:28 PM
hey, looks linear to me... RRFPR would have a line from it going to the manifold so it knew how much boost pressure was there.
#17 850drag
850drag
  • 1,353 posts
Posted 26 December 2005 - 09:41 PM
QUOTE(Slater @ Dec 26 2005, 05:52 AM) View Post
true but I am also thinking in long terms for him, as he mentioned he might be later on adding more upgrades to his vehicle.
2007 S40 T5 AWD
#18 chaze1385
chaze1385
  • 385 posts
Posted 27 December 2005 - 04:39 PM
You know those regulators from VMS are nothing special. They can be had for about 1/4 of that price. this look familiar
Chad
[font=Comic Sans Ms]94 850 turbo, 85 Merkur XR4Ti, 87 Chevy Sprint Turbo, 99 Grand Prix GTP
#19 550
550
  • 12,852 posts
Posted 27 December 2005 - 05:05 PM
hehe, non volvo specific? NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I fail to believe it.
So that is not rising rate right? Just yer normal everyday adjustable FPR.
#20 Slater
Slater
  • 3,198 posts
Posted 28 December 2005 - 03:17 AM
QUOTE(550 @ Dec 27 2005, 12:05 PM) View Post
FYI a lot of aftermarket FPRs are rising rate (AEM, some OE Bosch, etc). Pretty common stuff.
