Diagnosing Upper Strut Mount
13 replies to this topic
#1 3p141592654
3p141592654
  • 25 posts
Posted 03 January 2006 - 06:57 PM
While under the hood I noticed that there was about a 4-5mm gap between the top retaining cap and the strut mount (I think these are the right names based on the FCP Groton exploded view).
I have read up on the many posts on replacing the front strut mounts, but I have not seen any info
on diagnosing if they are bad other than hearing rattle noises over bumps (my car is not rattling).
Is the gap normal? I don't recall it being there in the past but my memory is not reliable.
2000 V70 SE
#2 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 04 January 2006 - 12:01 AM
"SMOKE TROUT NOT CRACK"
#3 GTM2U
GTM2U
  • 146 posts
  • Interests:Mechanics, physics, engineering, naval architecture, sciences, computers. Semi-retired NIASE Master Mechanic. Provisional teaching credential auto shop. Professional experiences include every major imported car brought into USA since '60's as well as restorations. Service Manager Nissan Subaru dealer. SAE associate. Former tech inspector SCCA. Estimated 20k-30k cars have my fingerprints as a lead mechanic and shop foreman.<br /><br />Hobies, sailing, yacht design, motorcycles, classical music, camping, my kids, and travel.
Posted 06 January 2006 - 06:33 AM
QUOTE(MrWinkey @ Jan 3 2006, 04:01 PM) View Post
If there is clearance all the way around what's to keep it from clunking when going over bumps?
Cheers,
GTM2U
S70
#4 Volvo Virgin
Volvo Virgin
    Fadeproof Rob Rock
  • 2,080 posts
  • Interests:Old Corvettes / Muscle Cars-currently driving/restoring a 70 Corvette convertible 350 4spd<br /><br />Off-roading-'89 Chevy C/K 1500 Short-bed pickup.Mods completed so far- 3&quot; lift / 33'&quot; BFG All-Terrains / cat-back dual exhaust.Mods to come- body work and fresh paint / 71&quot; vette motor transplant / lots more goodies <br /><br />PWC-97 Sea Doo GTX<br /><br />Dirt Bikes-sold my 99 Yamaha 350 Warrior.Have not replaced it yet
Posted 06 January 2006 - 08:56 PM
As I can see it and as I understand it,the spring seat/strut mount bushing is bolted to the bottom of the inner fender with the 3 studs/nuts you can see on the top of the inner fender surrounding the top strut mount.The top of the spring sits in the bottom of the spring seat,and the top strut mount comes thru the middle of it where it is secured with the assembly in question.Both are isolated from the metal body by the rubber compound of the seat/bushing.What you are looking at is just the top of the strut mount and the normal grommet/washer/nut assembly.If it is bad you should be able to see fractures in the rubber of the seat itself once you remove the grommet/washer/nut.
Edited by Volvo Virgin, 06 January 2006 - 09:00 PM.
Rob
99 S70
#5 A pimp named Slickback
    Board Pitbull
  • 670 posts
Posted 06 January 2006 - 09:15 PM
Want to know the super secret, factory trained, works every time way to diagnose broken upper spring seats?
That's right bitches. I'm back.
#6 MrWinkey
MrWinkey
  • 4,759 posts
Posted 07 January 2006 - 12:34 AM
Ok ...the gap is normal but what you need too look for is in the center of that mount (between the gap) look at the rubber around the edges where the strut top enters through it . If it is broken then that is probably the cause of your noise if you have one. Also if you do have noise look at the sway bar end links and squeeze the ball and socket ends for play they should be tight wink.gif
#7 3p141592654
3p141592654
  • 25 posts
Posted 07 January 2006 - 12:59 AM
QUOTE(swedespeed21 @ Jan 6 2006, 01:15 PM) View Post
2000 V70 SE
#8 MrWinkey
MrWinkey
  • 4,759 posts
Posted 07 January 2006 - 01:18 AM
#9 A pimp named Slickback
    Board Pitbull
  • 670 posts
Posted 07 January 2006 - 03:04 AM
QUOTE(3p141592654 @ Jan 6 2006, 05:59 PM) View Post
Take a 21mm wrench (7/8), put it on the top nut. Turn it to the right (tightening), if the nut has a lot of resistance, and springs back, the seat is just fine. If the wrench will turn the nut, and shock shaft all the way around, the seat is broken. That's how any dealer tech does it.
#10 3p141592654
3p141592654
  • 25 posts
Posted 09 January 2006 - 08:50 PM
Thanks to everyone that replied. For now, mine pass the test.
QUOTE(MrWinkey @ Jan 6 2006, 05:18 PM) View Post
2000 V70 SE
#11 Funkyd
Funkyd
  • 2 posts
Posted 11 October 2006 - 05:58 PM
I'm looking for an entire guide to replace the mount. Also if you're replacing the front mounts on both sides what else should be replaced. I have 118k on 01' t6. I don't see a service schedule and I don't want to touch this for at least another 60k.
#12 SkyWriter
SkyWriter
    I'm so back in the game!
  • 2,526 posts
Posted 11 October 2006 - 10:46 PM
QUOTE(swedespeed21 @ Jan 6 2006, 11:04 PM) View Post
that's the ticket. you can also turn it by hand when they are totally gone. you should also have noticed a distinct change in the ability of the car to take a bump without clenching your teeth.
I'm sad and lonely. Someone please hug me
#13 dmelviØØ7
dmelviØØ7
    Bi-Winning
  • 12,728 posts
  • Interests:Stuff and beer.
Posted 12 October 2006 - 01:38 AM
QUOTE(swedespeed21 @ Jan 6 2006, 08:04 PM) View Post
Super secret, I love it. A 30 second check for a gravy job. laugh.gif laugh.gif
Sonic Shenanigans
#14 MrWinkey
MrWinkey
  • 4,759 posts
Posted 12 October 2006 - 11:59 PM
Not always ....it could be torn only half way around and making noise but not allowing you to turn the top the whole way around wink.gif
