Mounting Ipd Anti Sway Bars
18 replies to this topic
#1 lux850
lux850
  • 38 posts
Posted 25 January 2006 - 09:12 AM
Having read great reviews on IPD anti sway bars I got to buying a pair for my 850 T5.
My question is regarding fitting them to the car. I dont have access to a lift or ramp to lift the car off the ground. I'm wondering whether I can get away with a trolley jack for the lifting?
Anybody done it this low tech way? Any angle on the practicality or safety of this method is of interest.
Thanks.
Volvo 850 T5 Oct 96 US Export Model
Polar White, 95K Miles, IPD Anti Swaybars, Bilstein Schocks,
Eibach pro street kit springs, Black Diamnond drilled, slotted front disks,
Black Diamond Predator brake pads, Luxembourg.
#2 WhiteT5
WhiteT5
    Sampson
  • PipPipPipPip
  • 4,828 posts
Posted 25 January 2006 - 12:27 PM
The rear bar is a piece of cake and can be done w/ jack and stands.
While the front bar is a good bit more difficult and time-consuming, it can be done w/o a lift. Some people have reported being able to fit the front bar w/o even lowering the subframe, but others have said that it is too tight of a fit. I did it the "right" way and lowered the rear of the subframe. To have the best control over this procedure, you'll either need a set of rhino ramps (the heavy duty ones) and a jack, or two jacks.
- Sean
#3 lux850
lux850
  • 38 posts
Posted 25 January 2006 - 01:55 PM
QUOTE(WhiteT5 @ Jan 25 2006, 01:27 PM) View Post
Food for thought. I had the feeling it wouldnt be quite straight forward..
Rgds.
#4 Vitor
Vitor
  • 272 posts
Posted 25 January 2006 - 02:55 PM
WhiteT5 is right on the money.
I gave up on trying to squeeze the bar in (or take out the old one) without lowering the subframe. It was only a waste of time.
The same goes for the rack and pinion assy.
Step childs 92 Chevy Suburban and '03 Mini Cooper S
#5 Zappo
Zappo
    The One Upper
  • 15,529 posts
Posted 25 January 2006 - 05:39 PM
QUOTE(lux850 @ Jan 25 2006, 01:12 AM) View Post
Thanks.
You don't need ramps, but jack stands are a must.
#6 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 25 January 2006 - 05:40 PM
QUOTE(Zappo @ Jan 25 2006, 09:39 AM) View Post
didn't we swap the IPD rear bar from the S70 to the V70 without jackstands? I really thought we did...
#7 Zappo
Zappo
    The One Upper
  • 15,529 posts
Posted 25 January 2006 - 06:16 PM
QUOTE(the underlord @ Jan 25 2006, 09:40 AM) View Post
yeah, you can do it with ramps, but the rear is easy compared to the front.
#8 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 25 January 2006 - 06:17 PM
QUOTE(Zappo @ Jan 25 2006, 10:16 AM) View Post
word to that.
#9 PullMyFinger
PullMyFinger
  • 1,311 posts
Posted 25 January 2006 - 06:45 PM
Just fyi...the rear is only easy if you have a stock rear bar already. Mine was a real pain to do since I had no stock rear bar to begin with. The delta links are the same and the holes are all in place but you have to do a lot of bending and prying and scraping and chiseling of undercoating and what-not to fit it in the box end. Its totally doable, just an extra pain and takes more time.
#10 Kashif
Kashif
  • 1,846 posts
  • Interests:Automotive repair
Posted 26 January 2006 - 02:03 AM
Should you replace the subframe bolts, and where would the jack fit, under the lower subframe bar?
#11 KLS
KLS
  • 727 posts
Posted 27 January 2006 - 06:55 PM
I had more trouble getting the rear bar in than the front. The front was just a lot of work. The rear didn't want to go, didn't want to go, didn't want to go...it slipped in. I had to loosen several of the rear suspension bolts...they are really tight, and must be retightened just as tight.
You'll need jackstands for the front, plus a way to support the engine subframe while it is loosened. A hydraulic floor jack did that for me. DO NOT go cheap and dangerous. Jackstands and a hydraulic floor jack don't cost much and are safe. There is no part on either you nor your car that you can get fixed for the cost of the jackstands and jack if the car falls.
After the sway bars are installed, you'll need a front and rear alignment. I like to add camber adjusters on the front and set them to -1° camber.
The IPD sway bars are the single best improvement I've done on the car.
Ken
Edited by KLS, 27 January 2006 - 06:57 PM.
#12 lux850
lux850
  • 38 posts
Posted 16 February 2006 - 03:52 PM
QUOTE(KLS @ Jan 27 2006, 07:55 PM) View Post
Ken
Thank you gents. Good to know what is ahead!
#13 lux850
lux850
  • 38 posts
Posted 18 March 2006 - 04:43 PM
QUOTE(lux850 @ Feb 16 2006, 04:52 PM) View Post
Gents, which tools are needed to lower the subframe? Does this require specialist volvo sockets?
I booked my car into my local garage and they took just 2 minutes to look and tell me they couldnt do the job cos they didnt have the tool(s) to lower it. Thanks.
#14 Superstitious-hyperrealist
  • 91 posts
Posted 18 March 2006 - 06:06 PM
just another quick question on installing the rear bar on a car that did not come with it. where do i get the nuts and bolts? can i get them at a hardware store or is it a dealer thing? i called groton and they don't carry them. anyone?
95' 855 ST chip, 80' 262c V8
#15 Patrick.
Patrick.
  • 5,707 posts
Posted 18 March 2006 - 06:28 PM
QUOTE(lux850 @ Mar 18 2006, 11:43 AM) View Post
what useless bunch of idiots!
#16 BeachRat
BeachRat
    Team GKT
  • 2,761 posts
Posted 18 March 2006 - 08:47 PM
QUOTE(the underlord @ Jan 25 2006, 10:40 AM) View Post
Would it be a factor of the condition of the engine mounts? I replaced both hydraulic mounts and the bracket on the passenger side after all three were totally blown. Not only did it drive much smoother, but I picked up a good 1/2" of additional clearance between the motor and the subframe.
QUOTE(lux850 @ Mar 18 2006, 09:43 AM) View Post
Wow. You're basically supporting the whole car, and then using another jack to push the motor up a bit to make room for the old bar to come out, and the new bar to go in. Unless Volvo makes a special "subframe jack" you just need to try another mechanic.
#17 MadeInJapan
MadeInJapan
  • 1,629 posts
Posted 18 March 2006 - 09:11 PM
Volvo has them...believe they are a size #8 (metric of course, but not mm)....you can ask your dealer. Actually, I would ask them and then go to the autoparts store and get them cheaper (get the bolts and nuts as a pair and then you'll know they'll fit, except for the endlinks, but you should have the hardware for that anyway. You don't want to go the hardware store route due to the threading. Also, if anyone has gotten IPD's newest nuts that are teflon on the inside, keep an eye on them. I had their swaybars put in my wife's '04 V70 and the next day there was rattling all over the front end. It was these nuts from their endlinks that had backed themselves off. Really cinch them down too and use lock nut.
'91 240 Sedan- Sold 4/21/09
#18 Guest_Guest_*
Guest_Guest_*
Posted 23 March 2006 - 07:57 AM
QUOTE(MadeInJapan @ Mar 18 2006, 09:11 PM) View Post
Thanks. I will see how cooperative our local volvo dealer is. They're generally not so helpful in these parts, particularly when you dont give em the business..too bad I say!
#19 KLS
KLS
  • 727 posts
Posted 23 March 2006 - 08:58 PM
I lowered and replaced the subframe using ordinary tools. The weight of the engine is on the subframe, so that must be safely supported and lifted back into place after the bar is in. Because the subframe carries the steering rack, an alignment is needed immedately after the bar installation. The rear also need an immediate alignment because the bolts there are loosened and retightened.
Ken
