Tires Size For A 15"
Posted 24 May 2004 - 09:21 PM
i'm hoping for a wider tire than the stock 195/60/15 size.
i'm wondering what the maximum tire width/size for a 15" rim would be without getting any rubbing
i know a lot of you don't have experience with 15" rims, but in theory, would it still be the same?
thanks
Posted 24 May 2004 - 10:12 PM
Volvospeed On Google+
Posted 24 May 2004 - 11:04 PM
sure i've read that you get some rubbing on full wheel steering, but i think that i should be able to hit maybe 215 or something
Edited by anitanium, 24 May 2004 - 11:04 PM.
Posted 25 May 2004 - 02:02 AM
Posted 25 May 2004 - 02:06 AM
but with aftermarket and some wheel spacers, they wont?
and will i notice a big handling gain if i went with 205's?
Edited by anitanium, 25 May 2004 - 02:06 AM.
Posted 25 May 2004 - 02:20 AM
No, 225 is too wide of a tire for the narrow stock rim.
Posted 25 May 2004 - 03:48 AM
Past:
94 850 160k sold
84 242ti 202k sold
99 F150 4x4 99k sold
#8 Guest_Guest_*
Posted 25 May 2004 - 04:00 AM
The improvement from a 195 to a 205 would depend much much more on the kind of tire than the tire size, as well as the benefits of a shorter (55) sidewall. When I bought my T-5R the OEM 17s were gone but after I replaced the FIFTEEN inch 195s with a 205-55-16 AVS 100, the improvement was great...a result of the soft AVS, not so much the size change. BTW the 100s lasted 16K mi and couple weeks ago I went to the new Kumho Ecsta ACX.
Posted 25 May 2004 - 04:03 AM
- V70 so stock
- Taurus NA
- und Das Silber Benz
Some people are like Slinkies. They're good for absolutely
nothing but a lot of fun to push down the stairs.
Before you criticize someone, walk a mile in their shoes.
That way, you're a mile away and you have their shoes.
Timing has an awful lot to do with the outcome of a raindance.
Posted 25 May 2004 - 04:10 AM
Can only tell you about the AVA 100s = terrific dry and rain traction. Near zero snow/ice traction (OK, zero) but Yoko does not say they are snow tires or anything close. As I said I got 16k mi. You can find wear range for all tires at tirerack.com, as well as revs per mi, diameter, tread width, etc. Great site. All 205-50-16s for example are not the same size. Check it out...
- V70 so stock
- Taurus NA
Posted 25 May 2004 - 04:42 AM
What about 225/45/16 on 16X7.5 40mm rims? would that rub on a non lowered suspension?
Or would 205/50/16 be too wide on 16X7.5 rims?
Edited by XtremePsionic, 25 May 2004 - 04:43 AM.
Visit my struts installation guide. http://members.shaw.ca/heeeeee/strut
Posted 25 May 2004 - 01:53 PM
Both those should work no problem
#14 Guest_Guest_Patrick_*
Posted 25 May 2004 - 03:03 PM
#15
Posted 25 May 2004 - 04:20 PM
If you are looking for something in between, go with the 205/55's. I certainly agree that a 225 is pushing the width for a 6.5" wheel. Although I have installed 225's on a 6" wheel and they looked funny. I also think that any perfomance increase gained from the wider tire was lost because of an improper fit.
I also have a set of the 711's on my Porsche. Because it is an H Rated tire the sidewalls are not as stiff as the 712's. Thefore it is a mushier tire although it has a more agressive dry handling tread pattern.
I think either the 711 or the 712 will be a good tire choice.
#16 Guest_Guest_NAteB_*
Posted 27 May 2004 - 01:22 AM
#17
Posted 18 October 2004 - 08:37 PM
2000 V70XC (converted to fwd)
1988 Schwinn Traveler
