Should This Hose Be Attached Somewhere?
7 replies to this topic
#1 Ludeless
Ludeless
  • 443 posts
Posted 26 February 2006 - 10:35 PM
I was in the process of replacing some of my rubber vacuum hoses w/ silicon ones and noticed this one hose not attached to anything on one end
It's the one in the middle here. It looked to me like it should attach to the Air intake as there was a nipple there on the underside of the hose after the MAF sensor.... Looks like it would fit this hose. Anyone know if this should be attached?
Here's a pic of the underside of the intake hose.
#2 Curtis G
Curtis G
  • 61 posts
Posted 26 February 2006 - 10:39 PM
Sure hook it up, looks like it goes there.
94 850 T5
#3 Detailsetc.
Detailsetc.
  • 312 posts
Posted 26 February 2006 - 11:01 PM
Yes it does belong there, maybe a good time to put a ziptie on it as well.
06/S60R/Rica/Ferrita/ViVA Hybrid Turbo/Stage 2
98V70T5M WI/FMIC/HBEAM/RICA/FERRITA DP/IPD EXHAUST/CUSTOM19T/APEXI/BMC/MSD/PP R MANI/ADJ CAMS
06XC70
#4 Ludeless
Ludeless
  • 443 posts
Posted 27 February 2006 - 10:33 PM
Thanks for the help... hooked it back up w/ ziptie goodness and the car seems to run so much better. I used to get a loud whistle type noise right for about 1-2 seconds after the car was first started but no more.
Something strange has happened a couple times that i haven't noticed before when putting the pedal to the floor. It's only happened maybe 25% of the time, but when i do this, the turbo kicks in and everything is great. But all of a sudden it's like the turbo or something just stops. There is absolutely no accelaration for about a second or 2. Kind of like what would happen when you hit a governor for top speed. Not sure if this is from the turbo, or the fuel cutting off or what....
Any ideas?
#5 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 28 February 2006 - 12:28 AM
That hose is nothing but relief for the boost....consider it a recirculated dump valve...instead of a blow off valve dumping it outside it dumps it back into the intake wink.gif
"SMOKE TROUT NOT CRACK"
#6 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 28 February 2006 - 02:22 AM
that will throw off vac readings and gas mileage I believe though.
good to hook it back up, or you could just plug it up on the pipe side and the BCS side and be done with it.
#7 SIAMBLUE
SIAMBLUE
  • 250 posts
Posted 15 March 2006 - 04:35 PM
Has anyone got a picture or a diagram or details where the hoses go, of the newer style bcs found on the s70's?
regards gary.
1998 V70R FWD manual in Saffron, 19t, Rica custom tune, THS intercooler, CDA, 63mm throttle body, RIP kit, 3" angled DP with race cat & 3" stainless exhaust system, Cooling mist WI 100% meth, KAD 6 pots with 330mm x 30mm AP discs, DS3000 pads.
Give blood tease an Akita...
#8 PullMyFinger
PullMyFinger
  • 1,311 posts
Posted 15 March 2006 - 06:58 PM
There should be a sticker on your hood or firewall, passenger side that details very clearly where all the vacuum lines go. Very thoughtful of Volvo to put that there, I've used it several times now.
