No Lights At Startup
6 replies to this topic
#1 uscgc70
uscgc70
  • 531 posts
Posted 27 February 2006 - 01:43 PM
This morning was fairly cold (17 Deg.) and when i started my car it started fine, but my headlights and dash lights did not click on for about 30 seconds and i can't turn on accesories like my seat heaters and rear defroster. i've noticed this happens more when its cold out, but its never taken this long for the lights to come on before. is there a relay thats starting to go? has anyone else had this problem or am i the only lucky one here?
2003 XC70
BFG Mud Terrains - To go where i need too.
IPD Skid Plate - To protect my oil pan
Yakima Road Warrior Rack w/ Spare Tire Mount - To carry extra stuff and ensure my return
Curt Hitch w/ Volvo trailer harness - To pull my tilt trailer that hauls my ATV's/Snowmobiles
#2 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 28 February 2006 - 12:16 AM
Sounds like an ignition switch problem too me. When it's cold things contract and your issues all seem to route towards the ignition switch ....Just a thought outta my drunken head wink.gif
"SMOKE TROUT NOT CRACK"
#3 uscgc70
uscgc70
  • 531 posts
Posted 18 September 2006 - 11:27 AM
So this came back hard core today. its been doing it off and on, usually when its cool out. is there a relay for all the electronics? it sounds like something clicks after i turn the heater on and the interior warms up, then everything comes on.
2003 XC70
#4 uscgc70
uscgc70
  • 531 posts
Posted 19 September 2006 - 02:30 AM
Come on guys, help me out here. does anyone know about a relay, or even just point me towards a wiring diagram. i must get this fixed. soon
2003 XC70
#5 S70driver2
S70driver2
  • 1,033 posts
Posted 19 September 2006 - 03:18 AM
i guess you can get one of those haynes books, i think thats how you spell it. or have you asked your local friendly volvo stealership i mean dealership?
if you dont like me i have one question..... why do you hate freedom?
MST? are you on Mexican Standard Time?
http://z3.invisionfree.com/VS_TX_Crew/index.php?showtopic=1 GO TEXAS!!!!!
#6 uscgc70
uscgc70
  • 531 posts
Posted 19 September 2006 - 01:39 PM
I haven't been able to find a manual specific to my car, and my local dealer just went under. is this info in VADIS?
2003 XC70
#7 Lynn Brockman
Lynn Brockman
  • 42 posts
Posted 20 September 2006 - 03:48 PM
Hi, USCGC70 - I have a couple ideas for you, but I'm not sure how correct they will end up being. I know that some of the C70/V70 cars had headlight switch issues, and for certain cars there was a recall for it. I think it was said that you could push the knob in towards the switch and the headlights would come on , if I remember correctly. For the other items, I wonder if your battery is ok, or if your alternator has been tested. It almost sounds like it lacks voltage, and then it clicks in and charges. I can watch my S60 lighting and see that there is a slight charging delay (maybe 5 seconds) on cold startup before it is at full voltage. Maybe the same issue is occuring on your car, only in a more pronounced fashion. You might check battery voltage before startup, then immediately after, and then check to see what it is when everything come on. Let me know how it goes. .
