Where Do I Begin?
31 replies to this topic
#1 VOLVO850SB
VOLVO850SB
  • 7 posts
Posted 03 March 2006 - 08:27 PM
Hey,
I just recently bought a 1994 Volvo 850T Wagon from an auction and just had it serviced because the flashing arrow and the check engine light came on. When I got it serviced, and I knew that there would be something wrong with it because face it, I got it from an auction so that was the risk that I took. Anyways, I took it to a Volvo dealership because I wanted to know EXACTLY what the problem was. He told me the following was wrong:
Transmission Flush needed
PNP switch replacement needed
Replace Knock Sensors
Replace Oxygen Sensors
Replace Speed Sensors
Replace some sort of other wires
Radiator is leaking coolant
and my Odomoter is broken
Now I know that it is a 1994 car, but it drives sort of okay, and I spent my money on it, should I give it up or for what I have to pay to repair it is it worth my time? I don't mind the repairs and I keep hearing that Volvo is a good car and if you keep up the maintenance it'll drive forever, which is the main reason why I got it. Help me out guys, where do I go from here?
'94 855 T5
#2 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 03 March 2006 - 08:31 PM
replace all that stuff..
#3 Figawi
Figawi
  • 3,116 posts
Posted 03 March 2006 - 08:34 PM
all that stuff you could do yourself just by reading off this board. get your parts from FCP groton and like kevin said, when your done you will have a 235HP wagon that will go another 200k at least.
Andrew
2004 Volvo V70 2.5T Titanium Edition
#4 VOLVO850SB
VOLVO850SB
  • 7 posts
Posted 03 March 2006 - 08:36 PM
QUOTE(the underlord @ Mar 3 2006, 08:31 PM) View Post
'94 855 T5
#5 bryan g
bryan g
  • 68 posts
Posted 03 March 2006 - 08:37 PM
QUOTE(VOLVO850SB @ Mar 3 2006, 03:27 PM) View Post
Hey,
A lot of that stuff you can do - this site has instructions or posts dealing with how to do them and it is not as hard as you think... I have a 94 850 turbo with 222,000 miles and I expect to get a heck of a lot more out of it!
Bryan
1994 Volvo 850 Turbo Wagon - 222,000 miles
#6 VOLVO850SB
VOLVO850SB
  • 7 posts
Posted 03 March 2006 - 08:38 PM
QUOTE(emerysmith @ Mar 3 2006, 08:34 PM) View Post
And where would I find FCP Groton? Would it be easier to replace the entire transmission?
'94 855 T5
#7 Mogatu'r
Mogatu'r
    Shiny Performance Racing.
  • 2,886 posts
QUOTE(VOLVO850SB @ Mar 3 2006, 08:27 PM) View Post
And you heard right! take it to a local volvo shop, dealers yank up price up the yingyang find someone local, and you'll be ok. You'll see after maintenance is done then you're goin to be moddin it, how many miles???
brinquedo 00R-M 309hp/385tq / '97-855R 26k miles on Volvo rebuild, Weitec kit / daily... 98 v70 t5 wifey...E36 m3 cooling system overhauled:check:
#8 Arnis
Arnis
  • 98 posts
Radiator is leaking coolant.
I had the problem and on topoil was going into colling sistem.so start with that. also owerheating engen is not good. this happend to me.
and my Odomoter is broken . there can be broken gear.I used that from audi c4 odometer.
so start with radiator
'96 855R
#9 VOLVO850SB
VOLVO850SB
  • 7 posts
Posted 03 March 2006 - 08:41 PM
Where can I find FCP Groton. Is there a website for it? Any why are Volvo parts so hard to come by. Can't I get the parts from the local AutoZone or PepBoys or Advance Auto Parts stores, or should I stick with the Volvo parts?
'94 855 T5
#10 Mogatu'r
Mogatu'r
  • 2,886 posts
Posted 03 March 2006 - 08:42 PM
QUOTE(VOLVO850SB @ Mar 3 2006, 08:38 PM) View Post
http://www.fcpgroton.com/volvo.htm#850, uh! no I guess unless you have a problem with it.
#11 Guest_AlvinL_*
Guest_AlvinL_*
Posted 03 March 2006 - 08:47 PM
Know about Bay13? Lots of helpful people her. You have a 94-850 so you can look for trouble codes yourself by reading here. You can do all that work yourself but if you're not comfortable, the dealer is a good place to start unless you know an indie you can trust.
FCPgroton.com for parts.
#12 Gaff
Gaff
  • 458 posts
Posted 03 March 2006 - 08:57 PM
QUOTE(VOLVO850SB @ Mar 3 2006, 04:27 PM) View Post
Hey,
Easy Peasy. +1 for the previous post search. $1000-$1200 if you have it done professionally.
2006 V70 2.5t, 31K
#13 Gaff
Gaff
  • 458 posts
Posted 03 March 2006 - 10:04 PM
QUOTE(James100 @ Mar 3 2006, 05:46 PM) View Post
If he went to the dealer to get those repairs done try tripling your $1000 to $1200 estimate if your lucky!!!!!!!!.....
ph34r.gif I was assuming an indy.
2006 V70 2.5t, 31K
#14 andrew_the_fox
andrew_the_fox
  • 704 posts
  • Interests:VOLVOS
Posted 04 March 2006 - 10:07 PM
QUOTE(the underlord @ Mar 3 2006, 03:31 PM) View Post
+1
do it
do it
#15 blazen244
blazen244
  • 280 posts
Posted 04 March 2006 - 10:40 PM
cool.gif Grab a 850 SHop manual and make em weekend project
95' 850 T-5
09' Suzuki GSXR 1000
Caddy Escalade
#16 Arnis
Arnis
  • 98 posts
Posted 05 March 2006 - 06:08 AM
Im not pro but I did change radiator myself. easy took me 3 h. all YOu need is 2 tools 10 and 12.and some philips thing and scroowdriver.
'96 855R
#17 wills
wills
  • 180 posts
Posted 05 March 2006 - 11:33 PM
I do believe the 94 850t is rated at 222hp, at the crank.
06 GTO LS2 (new project)
98 V70R (wife's car now)
94 854 T (surviving a teenager)
92 740 (my winter bomb)
01 Vmax
03 SV 650
03 Speed 4
05 Sprint
#18 James A Sousa
James A Sousa
  • 307 posts
Posted 05 March 2006 - 11:52 PM
WHOA BOYS, WHOA!!!
Ask the technician if he just tried a simple reset first. Did he look at your plugs?
Often one small problem can eventually throw several codes. Auction cars are started many times, revved up, and who knows what.
The first thing to try is to reset the codes and see what comes back. If you can, see what comes back first.
Often a major service and tune-up is a good way to get your used brick up to snuff. Something as simple as very bad air cleaner can cause other systems to mess up.
Fix the safety and urgent items first.
Don't put gunk in your cooling system, find the leak and fix it and/or replace the radiator. Many engines die due to overheating, so a new radiator and replacing suspect hoses can be a good investment.
Unless you cannot pass inspection, try driving the car a bit (once the cooling system is OK) especially a couple of gentle highway trips. You might be able to work off any "Lot rust" that the car has.
Edited by James A Sousa, 05 March 2006 - 11:59 PM.
#19 VOLVO850SB
VOLVO850SB
  • 7 posts
Posted 07 March 2006 - 03:46 PM
QUOTE(James A Sousa @ Mar 5 2006, 11:52 PM) View Post
WHOA BOYS, WHOA!!!
WHOA BOYS, WHOA!!!
Yes I am very new to this forum and I am a female so go easy on me. By the safety issues, do you mean the radiator? I just got a quote from the Volvo dealership that looked at it and they said $725 to replace the radiator. Now I went to the fcpgroton.com website to get a price on the radiator and I found one for $205 which is a good price. The only question I have is, since the radiator is a NISSEN (brand name) instead of a genuine VOLVO part would that be okay? I'm new so go easy. And can I replace it myself? Wouldn't that be simpler rather than paying $725?
'94 855 T5
#20 Guest_AlvinL_*
Guest_AlvinL_*
Posted 07 March 2006 - 04:24 PM
Hey,
Are you handy? If you are then you'd be way ahead as you'd be able to look after your car and save a bundle. Read up Bay13, read the codes, reset and see if any comes back after a short drive. That would definitley clear up the questions for the PNP, knock sensors, speed sensors, and oxygen sensors. Or at least buy you some time if the error codes for those items doesn't reappear. I'm guessing the speed sensor is the ABS sensor so if the ABS light is on, the ABS won't work. The code, when you read it, will indicate which sensor is the problem. Maybe it just needs cleaning, which you can do.
If you're not handy, at least knowing how to read the codes, what they mean, will help protect you when you visit a mechanic. Only fix what needs fixing.
From your list, it looks like you'll need to fix the radiator first and get the transmission flushed. If you can, read the codes, reset, go for a short drive and post back here for us any codes that return. We'll help you figure it out. What wires need replacing?
For example, here's a pinned post on repairing the odometer.
