I just bought this 96 850, heat was not working so i looked under the fuses and saw that #5 (ECC blower (speed4)) fuse 30a was not there... i shut off the car and putted a new fuse in... while putting it in there were some sparks and all of the sudden heat went on... car is off at this point and heat control is at 0/off.
did anyone have similar problem?
Heat Problems.
Started by yrka, Mar 05 2006 04:28 PM
8 replies to this topic
Posted 05 March 2006 - 04:28 PM
Posted 05 March 2006 - 05:58 PM
Does the heater now work with the new fuse in or has it blown the new fuse? If it works, you're home free; if it blows, you obviously have some sort of short that you need to find or the blower motor is completely shot.
- Bill
2000 S70 GLT se
2003 S60 T5
2000 S70 GLT se
2003 S60 T5
Posted 05 March 2006 - 06:28 PM
New fuse works...and does not blow, but heater controls still dont respond.
Posted 06 March 2006 - 04:56 PM
Is the blower motor working? Do the lights on your recirc. and AC rocker switches flash when you turn on the blower? Do you get any heat after the car has warmed up and the selector switch is set to defrost?
- Bill
2000 S70 GLT se
2003 S60 T5
2000 S70 GLT se
2003 S60 T5
Posted 06 March 2006 - 07:24 PM
What do those flashing lights really mean. When I turn on my AC (which doesnt work) those lights flash at me. I already know the AC doesnt work. A few months back I had the refrigerant spray out into my car. Im guessing this would be the evap but the dealer said that my AC condensor (maybe compressor) may be about to go on me. My guess was the evap but I could be wrong. Someone please tell me Im wrong.
Sparks arent good man. Check the ground lines to make sure they are all connect properly. That would be my best guess as to what caused sparks. In the mean time take out that fuse and dont turn on your heater.
Tony
1997 854R || 2010 Triumph Street Triple R
Posted 07 March 2006 - 01:00 AM
Electronic climate control system fault codes are obtained from B1 socket. Codes are listed on p. 3-10 of Haynes manual or I'm sure could be found by doing search in this forum.
- Bill
2000 S70 GLT se
2003 S60 T5
2000 S70 GLT se
2003 S60 T5
#7 Guest_Guest_chad_*_*
Posted 22 March 2006 - 08:01 PM
I'm having the same problem, when I went to pull the codes, they Volvo code reader couldn't communicate with the system.
Posted 23 March 2006 - 04:13 AM
I think they have them on Bay 13 but don't hold me to that.
Posted 23 March 2006 - 08:34 AM
Are you saying that the heater blower is running even with the ignition OFF? Even with the key removed from the ignition?
'95 850 Turbo Wagon
This topic is locked
