Hello all,
i've been having a bad smell in the comaprtment after The car get into operating temperatur and especialy when i drive the car hard. my guess is that it's the smell of vaporized oil. i'm loosing oil also about 1liter/1500Km.
this is a N/A car so no turbo leak . i see oil on the top of the engine near the oil cap but not a pool just oil residue. i've changed the oil cap rubber ring but no improvement.
i have also higher than usual fuel consumption i noticed that after cleaning my fuel injectors.
car: volvo sedan 1995 850 GLE
what do u advise?
Bad Smell+ Oil Loss
Started by highhighs, Mar 08 2006 05:47 PM
9 replies to this topic
Posted 08 March 2006 - 05:47 PM
Volvo 850 GLE 1995 sedan
HU: JVC KD-G801
4 channel amp:
Pioneer GM-4000F 140Watts rms amp bridge into 2 channels at 70 watts rms
USAcoustics USC2100 300w rms (bridged)
12" JBL GT4-12 sealed box 1qft with dacron fill.
6.5" Earthquake Focuse6.5 2 way speakers kickpods up front.
HU: JVC KD-G801
4 channel amp:
Posted 08 March 2006 - 07:30 PM
what do u advise?
what do u advise?
One of your fixes is = you need a new oil fill cap($12 at dealer)..Just the gasket alone does not fix the problem .
I would look under the car for oil leaks and clean as much off as you can with rags as a start....
Check Engine Codes OBDI
Stage 0
PCV Pics
Stage 0
PCV Pics
Posted 08 March 2006 - 08:00 PM
thanks mate, first thing in the morning i'll go get one
HU: JVC KD-G801
4 channel amp:
HU: JVC KD-G801
4 channel amp:
Posted 08 March 2006 - 08:36 PM
You might want to look into getting Rhino Ramps if you are going to be going under the car alot...They are low cut....$20 to $30 in U.S.
Stage 0
PCV Pics
Stage 0
PCV Pics
Posted 08 March 2006 - 09:24 PM
will look into that but i have to find a dealer since i'm not a resident of the US
HU: JVC KD-G801
4 channel amp:
HU: JVC KD-G801
4 channel amp:
Posted 09 March 2006 - 03:16 AM
Lebanon? wow, that could make things difficult to find!
get under the car, and see if you see any oil seeping out underneath.
could be a blown RMS, or check if the oil is coming from the front or back of the block, on top of the engine. cam seals can leak too.
Posted 09 March 2006 - 05:24 AM
will do that thanks.
I found a DIY ramp :http://www.mustangworld.com/ourpics/News/mwramps/
i think i will try to do these
HU: JVC KD-G801
4 channel amp:
HU: JVC KD-G801
4 channel amp:
Posted 27 March 2006 - 10:00 AM
i checked today the car after driving it, and there was oil on the outside of the dipstick tube and when i remove it there were smoke comming out of the tube. this is the signe of what, how should i proceed to resolve the oil loss problem?
Thank you all
Thank you all
HU: JVC KD-G801
4 channel amp:
HU: JVC KD-G801
4 channel amp:
Posted 27 March 2006 - 06:38 PM
Thank you all
Thank you all
That's a sign that your PCV system isn't functioning. You definitely need to get that addressed before (hopefully it didn't already happen) your rear main seal (rms) lets go. It could be a simple vacuum line to the pcv system that's shot. I don't have a link on hand but I'm sure you'll find a lot if you search this forum for pcv system. In my case, I was lucky that the pcv was fine but it was just a vacuum line that connects to it that was broken. If you fix the pcv system, there shouldn't be smoke coming out the dipstick tube anymore.
And don't worry about the oil cap if you haven't bought one yet. If you fix the pcv, it won't be blowing oil up there that much so it shouldn't go out the cap anymore
94 855t
Posted 27 March 2006 - 06:59 PM
Thank you. i'll research the PCV thing
HU: JVC KD-G801
4 channel amp:
HU: JVC KD-G801
4 channel amp:
This topic is locked
