98 V70 Xc - Grinding - Clunking Noises
7 replies to this topic
#1 awlb
awlb
  • 4 posts
Posted 10 March 2006 - 09:10 PM
I am at a loss as to what might be causing my problem, and hoping for some insight before I trek off to the dealer with an open wallet.
Last week, car made a slight 'thumping' noise from underneath, esp. on bumpy roads - I thought it might be one of the hangers for the exhaust system had gone again, and I was getting some sway and the pipe was banging. Today, the car begins to make a very serious grinding sort of noise - coming from up front. Its cyclic, so when at idle the grinding noise comes and goes as the RPMs shift slightly. On acceleration, it gets very loud (and you can feel it in the pedal as well) for a brieft moment until the RPM's increase, and then it is gone - until you come to the next red light.
Anyone have any thoughts? By waiting to fix what I think are the hangers did something else loosen up? Love to have some idea before I get into the dealership...
Also on that note, I am about 30 minutes west of Boston - my company moved me here so I don't know the area very well. Anyone have a good non-dealer Volvo mech they can recommend?
[A side note, the car just rolled 99K, has been a great car all around, and after reading some of the posts, I see that it's not just mine that has had problems with the TRACS/ABS lights, bubbling door panel, etc. I have had the TRACS/ABS module replaced three times over the last three years.]
Thanks in advance
Edited by awlb, 10 March 2006 - 09:16 PM.
'98 V70XC no more... now 2004 XC70
#2 v70XXXc
v70XXXc
  • 79 posts
Posted 10 March 2006 - 10:18 PM
look at the front (actually right side) engine mount. it is a lump of rubber and metal that holds the engine off the subframe. the rubber broke and caused the same symptoms on my XC.
its a pretty easy fix, there are instructions in the repairs section of this site.
hint: its behind the passenger side front fender lining.
2005 V70 R Black/Nordcap
1998 V70XC Black/Charcol
1996 850 Turbo Red (Traded)
1987 740 Battlewagon 336,001 miles (R.I.P.)
#3 MakGT
MakGT
  • 168 posts
Posted 11 March 2006 - 08:05 AM
also check exhaust shields
96 Turbo
#4 James100
James100
  • 874 posts
Posted 11 March 2006 - 06:41 PM
QUOTE(awlb @ Mar 10 2006, 01:10 PM) View Post
Thanks in advance
Who was doing your Tracs/ABS module work and how much was it running you? I wouldnt go back again to them if I were you.
Check Engine Codes OBDI
Stage 0
PCV Pics
#5 mbsl98
mbsl98
  • 697 posts
  • Interests:cars, boats, skiing, family, travel
Posted 13 March 2006 - 04:38 PM
Welcome to Metro West. I use an Indy in Natick, Mike Andrews at Foreign Car Care - 508-655-1380. Used him for past 15++ years as my exclusive mechanic on lots of Volvo's. He is solely Volvo, and a great resource. Also walking distance to train to Boston.
Mike Sullivan
Currently: '09 XC70 T6 (3k); '95 855T (128k),'84 MB 380SL (94k summers only).
Kids cars: '98 S70 T5M (130k), '98 V70 M (116K).
Prior Volvo's: '85 744 (256k), '86 245 (165k), '86 245 (195k), '88 745 (208k), '91 745 (196k), '93 965 (147k), '95 855 NA (190k), '98 XC (98k), '07 XC70 (40k).
#6 awlb
awlb
  • 4 posts
Posted 13 March 2006 - 08:20 PM
QUOTE(MakGT @ Mar 11 2006, 03:05 AM) View Post
QUOTE(James100 @ Mar 11 2006, 01:41 PM) View Post
Farrell Volvo was doing the work - always under warranty and after the idiot light on the dash came on. I have had it replaced each of the last three years. This year (fingers crossed) not yet...
Once I find a decent indy I won't be going back...
QUOTE(mbsl98 @ Mar 13 2006, 11:38 AM) View Post
Perfect. I am right up the hill from him then. Thanks! I will give him a call in the future!
QUOTE(v70XXXc @ Mar 10 2006, 05:18 PM) View Post
thanks - that's what it is!
Edited by awlb, 13 March 2006 - 08:16 PM.
#7 awlb
awlb
  • 4 posts
Posted 14 March 2006 - 07:56 PM
QUOTE(awlb @ Mar 13 2006, 03:20 PM) View Post
NB: Now, according to the dealer, it also needs a power steering pump and a new alternator. As with the TRACS/ABS modules, this will be the third one... mad.gif
#8 James100
James100
  • 874 posts
Posted 14 March 2006 - 08:01 PM
QUOTE(awlb @ Mar 14 2006, 11:56 AM) View Post
Third?????? are you refering to PS pump or Alternator.....
Stage 0
PCV Pics
