Couple Of Problems With 850
Posted 12 March 2006 - 04:10 AM
i have like not poor acceleration but not 9 second accelerationa as it says everywhere mine probably takes like 11.5
i changed almost everythin there could be (fuel filter,spark plugs ,air filter ) what else can play a major role in acceleration??
second problem just happened yesterday all of the sudden overdrive arrow started to flash any suggestions (relay?)
and my rear brakes killing me with a noise i discovered there are shoul be shims mine didnt had it before so installing them i would stop a noise but still noise appears what else i can do to fix it (turn rotors?)
i also curious about my radio i have sc811 and there connection for an amp
if i want to have one sub do i need an amplifier or i can connect straight to sub?
Please Help!
Posted 12 March 2006 - 04:14 AM
Posted 12 March 2006 - 04:21 AM
168 bhp aint' much..
and the Up arrow flashing could be the sign of bad PNP switch.
Posted 12 March 2006 - 04:25 AM
i read everywhere is says it should be around 9 seconds
Posted 12 March 2006 - 04:26 AM
what kind of MPG do you see? car run well?, no cold start issues, when was the last time the Plugs/Wires/Dizzy/Rotor were changed?
Posted 12 March 2006 - 04:29 AM
car runs pretty good no problems
no cold start plugs new,air filter new fuel filter new and etc
maybe o2 sensor??
Posted 12 March 2006 - 04:31 AM
maybe o2 sensor??
well, the 18-20 in the city would make me think that your O2's are ok..
where did you read 0-60 in 9 seconds?
Posted 12 March 2006 - 04:32 AM
so you thinks its impossible to get 9 seconds?
Posted 12 March 2006 - 04:36 AM
'91 240 Sedan- Sold 4/21/09
Posted 12 March 2006 - 04:41 AM
ya that's what I was thinking... I mean a T5 0-60 Stock is 7.4...
Posted 12 March 2006 - 04:44 AM
#17
Posted 12 March 2006 - 05:06 AM
thanks for help but where other people want to hear their opinions about my problems
#18
Posted 12 March 2006 - 05:08 AM
it's saturday night.. so not that many people on... give it some time.
#19
Posted 12 March 2006 - 05:10 AM
#20
Posted 12 March 2006 - 05:11 AM
Edited by James100, 12 March 2006 - 05:12 AM.
Check Engine Codes OBDI
Stage 0
PCV Pics
This topic is locked
