Fpr?
4 replies to this topic
#1 TRACStar
TRACStar
  • 2,417 posts
Posted 12 March 2006 - 08:20 PM
Last night I was on the highway, I went to pass someone and the car downshifted and pulled to about 4000-4500 rpms and then kind of evened out and did not want to rev higher. Stopped at a red light later on and punched it through 1st gear and same thing happened.
I checked the valve on the end of the fuel rail and it barely had any pressure, cycled the key and still not too much pressure. I know it should be quite a bit of press. i'm thinkin at least 45psi
Question is could a bad FPR cause the power loss at higher rpm's?
#2 pfeener
pfeener
  • 950 posts
Posted 12 March 2006 - 10:28 PM
Yep, sure could, but it's also the classic symptom of a clogged fuel filter or a fuel pump that's getting really tired.
'98 S70 GLT
#3 TRACStar
TRACStar
  • 2,417 posts
Posted 12 March 2006 - 11:34 PM
fuel pump is 2 weeks old (walbro 255lph)
I will change the filter tomorrow
With a fresh pump is it good to change the filter anyway (particles and such from new pump)
#4 pfeener
pfeener
  • 950 posts
Posted 13 March 2006 - 02:31 PM
Never hurts. I would change it out with the pump. New pump could also be defective - unlikely but possible or like you first suggested could be the fuel pump regulator, but you should have 40 - 44 PSI of pressure at the rail. You also have a test port between the filter and the tank which you could use to test for a clogged filter.
'98 S70 GLT
#5 Beiner
Beiner
  • 278 posts
  • Interests:Bricks, gas turbines, heavy duty equipment. Pretty much any things that runs off of petroleum products.
Posted 13 March 2006 - 04:03 PM
QUOTE(850T_Wagon @ Mar 12 2006, 02:20 PM) View Post
Same thing happens to my XC. After I put a set of Samco's and silicone lines on I thought that I may have missed something. I still am getting P0171 for a code mad.gif but the cars "stalls" @ about 4k. I was thinking that when the relay failed, it failed. Nothing intermittent.
On that note, how do you test the relay?
'98 V70XC
'95 855 GLT
'83 245 DL
Your LPT does what?
