Roof Rack Weight Capacity?
7 replies to this topic
#1 tmckinn
tmckinn
  • 11 posts
Posted 13 March 2006 - 06:13 AM
A friend of mine wants to give me his old Sunfish sailboat. The hull weighs about 120 lbs. I have a Yakima roof rack that I frequently use on my 850 wagon. What is the roof weight capacity for Volvos? Can the roof (using the correct Yakima fittings for the Volvo) take a 150 lb or so load?
http://www.sunfishsailboats.com/
Thanks.
'95 855 Turbo
Seattle
#2 AkitaWagon
AkitaWagon
  • 138 posts
Posted 13 March 2006 - 09:01 AM
QUOTE(tmckinn @ Mar 12 2006, 10:13 PM) View Post
Thanks.
The Thule rack (same as OEM Volvo) I have on my 855 came with warnings to not to place a load exceeding 165 pounds on the load bearing rails. There might be a conservative margin for safety with that weight.
You can probably check the Yakima website for their load restrictions.
Some of the stories on the forums describe accidents where the car/wagon ended flipped over with the entire weight of the car resting securely on the roof rails with no collapsing, but then there's always the other pictures of the guy that overloaded and killed his suspension system or forgot to secure something and ended up jettisoning the load on the highway.
1997 855R 102k
1995 855GTA 259k
1993 850GLT 201k KIA...
#3 Sinbad
Sinbad
  • 845 posts
Posted 13 March 2006 - 09:29 AM
Hiya
150lbs should be fine. Just be careful when you drive - it raises the car's center of gravity quite a lot, with increased body roll and worse handling tup.gif
2006 SEAT Ibiza Cupra TDI
#4 Drew
Drew
  • 191 posts
Posted 13 March 2006 - 03:22 PM
The Yakima racks are rated the same 165lbs that the Thule racks are. The rack will be fine, I cannot comment on the roof of the car...I have no idea.
Keep in mind that it's not going to be fun getting the thing on and off of there and you risk messin' up both the brick and the boat....
Why not just pick up a small trailer? A decent used single jetski trailer can be had for under $200...
98' S70 GLT Auto with a little turbo.
#5 Figawi
Figawi
  • 3,116 posts
Posted 13 March 2006 - 05:21 PM
i think my OEM rack holds 220 lbs. i'd rent a trailer from UHaul or something though.
Andrew
2004 Volvo V70 2.5T Titanium Edition
#6 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 13 March 2006 - 05:29 PM
QUOTE(Drew @ Mar 13 2006, 07:22 AM) View Post
cause then you have to have a ugly reciever hitch showing on your car..
#7 Drew
Drew
  • 191 posts
Posted 13 March 2006 - 08:25 PM
QUOTE(the underlord @ Mar 13 2006, 12:29 PM) View Post
rolleyes.gif versus a Sunfish on the roof??? Lookin' like the Beverly Hillbillys with grandma sittin in the rocking chair!! biggrin.gif
Also which is more ugly? A 1" receiver plug on the back or a Yakima rack on the roof? wink.gif
#8 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 13 March 2006 - 08:30 PM
QUOTE(Drew @ Mar 13 2006, 12:25 PM) View Post
PS - I used to Race Lasers.. Sunfishes.. lol..
