Catalytic Converter Problem Again, Help
#1 Guest_Guest_RK850_*_*
Posted 13 March 2006 - 07:00 AM
Now I'm driving it 50 miles a day for a month. I start hearing the rattle noise near the cat area. It's the same sound I heard when the OE cat failed 6 mos again. I'm think the new cat is starting to fail again. Something is not running right on my engine that causing my cat to fail again.
My car is running fine. No hesitation, good gas mileage, check engine light is not on, plugs, cap and rotor have been changed about 20,000 mi ago. Can the spark plug wires be the cause? My wire are 130,000 mi old. It does burn some oil. About 1 qt every 7k or 8k miles.
Anyone has any idea?
Thanks,
RK850
96 850 n/a auto
Posted 13 March 2006 - 07:12 AM
Edited by James100, 13 March 2006 - 09:03 AM.
Check Engine Codes OBDI
Stage 0
PCV Pics
#3 Guest_Guest_*
Posted 13 March 2006 - 11:56 PM
Posted 14 March 2006 - 05:40 AM
a muffler guy said my new cat color has changed and might be overheating.
Dr. Fox Diagnosis
I aint even a pro like the guys on this forum but those are the tell tale signs: YOUR RUNNING TOO RICH!
First, scan your OBDII for error codes, you might find one indicating that your engine is running too rich which causes the catalytic converter to overheat. Check the fuel pressure regulator, and check for faulty or clogged fuel injectors.
The rotten egg smell that you mentioned is usually also caused by a fuel mixture in the engine that is too rich. The catalytic converter may be faulty but before you replace it the fuel mixture needs to be corrected.
Posted 14 March 2006 - 06:50 AM
I am Kale. I drive A 1997 850R. I love it.
#6 Guest_Guest_RK850_*_*
Posted 14 March 2006 - 07:24 AM
If my engine is running rich, which i think it probably is, won't the check engine light go off? I don't have a ODBII reader. If I get one, will it tell me what's wrong?
How do I adjust the fuel mixture? using the ODBII reader? For older Bosch F.I. on my BMW and Alfa, I can adjust it by the screw on the airflow meter. But the volvo airflow meter looks different.
I think I'll change the wires and the plugs this weekend.
RK850
Posted 14 March 2006 - 07:34 AM
RK850
As far as I know there is no way to change the A/F ratio on our cars without the ECU being reflashed. This would require more than an OBDII reader, and is not really your problem anyway. And also, unless extremely rich you would not be getting a CEL code. I would do those two maintenance things as soon as you can, and most likely replace your O2 sensor again. I don't know how you could have ruined a cat in just 6 months, unless you were running VERY rich. Get these things done and your CEL will go away for sure, but I dont know about the rattling your experiencing in the cat. I would just cut it out and put a straight pipe there if I were you...
Posted 14 March 2006 - 07:56 AM
RK850
You should register and put location in this will help out....
Depending where you live you can go to Autozone for the OBDII reading.....In CA (Los Angeles area) you put a deposit down on it as a loaner tool of about $150....In other places(states) I think they will read it for you for free...So you really dont need to buy one if your CEL light is on if you want to save cash for now....
I dont believe you will have any codes in there because your CEL light never came on so there shouldnt be anything in there to read....So I dont think that is going to do you any good...But I was just reading someones other post today (Tuesday 3/14) and he says when he clears codes he keeps getting 443 (Three way Cat efficiency) and it doesnt throw the check engine light.....So maybe you should try to read codes....
I would check your plugs first to see whats going on in the engine...The O2 sensor affects fuel so I would want to know the part # to make sure it was the correct one....
Edited by James100, 14 March 2006 - 07:02 PM.
Stage 0
PCV Pics
Posted 14 March 2006 - 07:04 PM
Here is the post Cat
Edited by James100, 14 March 2006 - 07:05 PM.
Stage 0
PCV Pics
Posted 15 March 2006 - 04:15 AM
leaded racing fuel?
Posted 15 March 2006 - 04:43 AM
Its not burning or throwing off any smell. I went through everything and everything (at least on surface) is running tip top. I am averaging 23-24 miles per gallon, O2 sensors are new etc etc... but the cat is now falling apart (loose inside).
Its A&B brand, which is one of the nicer more expensive aftermarket cats.
~1995 850GLT- 140,000 miles, some cosmetic additions but pretty much stock
~1999 V70- 105,000 miles
Posted 15 March 2006 - 01:36 PM
That really sucks... You might want to check your exhaust hangers for excessive wear but... Other than that I have no idea what could be ruining a high dollor cat in 6 months.
#13 Guest_Guest_RK850_*_*
Posted 15 March 2006 - 05:19 PM
Mine too is running fine and smooth. Also average 23/24 mpg and gets 29/30 long distance hwy. I have the same A&B from Frcton(I never remembered that fking name, they should change it to something else like ABC parts or something).
I'll pull the spark plugs and look at them this weekend. I'm going to get new OE wires and Volvo plugs. I put the non-Volvo plugs plugs about 25k mi. Maybe those plugs ruined my old CAT. I'll put my K&N cone filter back in the car. In case if it is running too rich, hope the K&N will let the engine sucks more air.
Thanks so much for all the input. You guys are great.
RK850
96 850 NA 120k mi
#14
Posted 15 March 2006 - 06:05 PM
1)1994 850 Catalytic Converter, What's that rotten egg smell?
2)Sulfur/rotten Egg Smell
3)New Cat Now Rotten Egg Smell, new cat rotten egg smell
4)Slight sulfur/rotten egg smell from high flow catalytic converter
5)Below is off an other site
"A harsh smell coming from the exhaust can usually be attributed to the use of fuel that contains methanol (Although in most places it is not supposed to be sold). When using this fuel, a sulfur smell can be emitted from the exhaust which can range from a mild odor to a rotten egg smell. To avoid this smell try changing the place where you purchase fuel! Catalytic Converter failures can also cause this same smell!"
Edited by James100, 15 March 2006 - 06:56 PM.
Stage 0
PCV Pics
#15
Posted 20 March 2006 - 12:29 AM
I just put my K&N cone filter back in the car. In case if it does run rich, the cone filter can give the engine more air and run a little less rich, I think/hope.
Thanks for all you guys input on this.
RK850
This topic is locked
