Does anyone know if the wheels from the newer Volvo's (S80, S60, post 2000 V70) will retrofit to an 850? the bolt parttern is the same, but it is possible that the offset is different for the new front suspension.
Do Wheels From Post 2000 Volvo's Fit Earlier 70's And 850?
Started by mbsl98, Mar 13 2006 03:24 PM
Posted 13 March 2006 - 03:24 PM
Mike Sullivan
Currently: '09 XC70 T6 (3k); '95 855T (128k),'84 MB 380SL (94k summers only).
Kids cars: '98 S70 T5M (130k), '98 V70 M (116K).
Prior Volvo's: '85 744 (256k), '86 245 (165k), '86 245 (195k), '88 745 (208k), '91 745 (196k), '93 965 (147k), '95 855 NA (190k), '98 XC (98k), '07 XC70 (40k).
Posted 13 March 2006 - 03:25 PM
yes.
"i can read most any drivers moves and react accordingly. plus its halrious when they're maxed out and u draft by them like a cakewalk." - HTownTurbobrick
Chris | 95 850 Turbo | ITS SLOW
Posted 13 March 2006 - 07:15 PM
yep, bolt pattern is the same, but width and offset are usually bigger, so you may need spacers with the new wheels, depending on the suspension/lowering modifications to your 850
Posted 13 March 2006 - 07:25 PM
or hub rings if the rims are from the XC90.
This topic is locked
