Lifespan Of A Turbo
Posted 13 March 2006 - 03:50 PM
2004 Volvo V70 2.5T Titanium Edition
Posted 13 March 2006 - 03:59 PM
Posted 13 March 2006 - 05:07 PM
Posted 13 March 2006 - 05:14 PM
Posted 13 March 2006 - 05:16 PM
I have a 1994 850 with 222,000 miles, the turbo is still alive and kicking with very little oil going into the intercooler piping. I believe that maintenance is the key to a long lived turbo... the previous owner had the oil changed every 5000 religiously.
Bryan
Well, like they say here, "If it ain't broke, don't fix it". Is there something wrong with it?
Posted 13 March 2006 - 05:20 PM
all of my 850's with turbos work like champs.
Posted 13 March 2006 - 05:32 PM
1) First thing in the morning, allow engine to warm up before leaving driveway.
2) Drive car for 3-5 miles, before going into boost.
3) As you approach your destination, drive car easy, without going into boost.
4) Idle engine near 1,000 rpms for 20-30 seconds, before turning off ignition. This allows oil to cycle thru oil cooler. Idle engine for over 1 minute, after driving on long trips or long periods of boost.
Posted 13 March 2006 - 05:39 PM
5) don't boost. period.
Posted 13 March 2006 - 06:25 PM
bingo.
i would never change a turbo until it is problematic. the mitsu's don't self destruct quickly like KKK's can. they just wear out slowly. so why change it?
Posted 14 March 2006 - 12:22 AM
Corey
1997 855 AWD 5 speed
Posted 14 March 2006 - 09:05 AM
"yeah yeah, but it's fresh/cooled OIL."
the water flowing through there will remove more heat than the oil will in the same amount of time, and if you are using quality oils and not ragging the piss out of the car just before you beat it off major coking wont be an issue.
my 85 cents
1998 Jetta TDI
www.savetheinternet.com
#14
Posted 14 March 2006 - 09:08 AM
Speaking of which, I found that there are some cars out there that have a feature built in where the oil pump (electric, I suppose) will continue to run for a predetermined amount of time after shutdown to help preserve engine parts, turbos, etc. And there was a device marketed back in the 80's that was bolt-on auxiliary oil pump that would pump oil before you started the engine (to get it up to the lifters and such) and run for a few minutes after shut-down to preserve your turbo.
-Valentin (car)
1996 854T, B5234FT, 100K miles. Anthracite Grey on Grey Leather. K&N Drop-in Filter, Columbas on BF Goodrich Traction T/A. Swedish Flag sticker on trunklid, concealed Valentine One installed. Narva Rangepower low beams. Speedtuning 17PSI ECU, TD04HL-16T turbo from Erievovo.
#15 Guest_Guest_whilst_*_*
Posted 14 March 2006 - 03:39 PM
1 qt. per 1000k is good. 15-1700k per qt. is excellent.
There is a "pre-pump" for lube still on market-$300+.
"After run" pump is an aux. water pump to circulate coolant-Audi,etc.
#16
Posted 14 March 2006 - 07:11 PM
The car still uses "no" oil between routine oil changes, although I have noticed some dampness around the intercooler weep hole for about the past 100,000 miles. But not enough to take the oil level down to the point where it's worthwhile to bother to add something.
I've used Mobil-1 10W30 since the car was new.
#17
Posted 14 March 2006 - 07:17 PM
Nick | 1998 S70 T5 SE | In the works: stuff
Parting: 2004 C70 Vert, 2002 C70 Coupe, 2000 C70 Coupe, 2000 V70R, 1998 V70R, 1999 V70R, 2000 S70 GLT SE
#18
Posted 15 March 2006 - 01:01 AM
'91 240 Sedan- Sold 4/21/09
#19
Posted 15 March 2006 - 03:20 AM
#20
Posted 15 March 2006 - 03:49 AM
Then why get a turbo model????
hopefully this summer i can get enough money to have the engine cleaned and tuned (shave piston heads, new gaskets stuff like that) is there anything i can do with the turbo, maintence wise????? since im gonna have the engine torn apart (proffessionally) then i can ask them to do the turbo to but besides new blow off valves (maybe im not 100% sure yet) i dont know what to ask them to do with the turbo????
and for some reason my turbo isnt a 100% this is what my gauge looks like ((((|).))) and the dot would be where the needle goes to. there use to be a hole in the turbo hose and it went about the same then i had that replaced and it went all the way to the right of the gauge into the white part now it doesnt even go halfway again into the white again so i checked all the tubes and everything again just a quick check but i dont know whats up wit it.
</center>
This topic is locked
