No Indicator Flash With Central Locking
Started by cornelius nepos, Mar 13 2006 06:28 PM
10 replies to this topic
Posted 13 March 2006 - 06:28 PM
Volvo 850 Estate/Sedan, 1994 (UK market) . Vehicle is fitted with factory Central Locking/Alarm. The system locks/unlocks all doors with remote. However, the indicators do not flash when locking/unlocking. How do I get the indicators to flash? LED on dashboard functions. Please, does anyone know how to activate the flashers. I asked at the local Volvostealers, but was told by a surly service desk person that the car needed to be plugged into their computer. Being a cynic about Volvo servicing, I believe this was merely to get into my wallet! Can anyone help please?
Posted 13 March 2006 - 07:01 PM
what.. isn't flashing? the four ways?
as far as i know, at least with the american volvo's, the 4-way's don't flash when locking/unlocking..
the led on the dash will blink when the doors are locked, however.
edit: i mean 850's
edit: i mean 850's
Edited by pete0r, 13 March 2006 - 11:14 PM.
1995 855 Turbo - 190k Miles
Posted 13 March 2006 - 07:15 PM
70 series corners flash when locked via fob..
Posted 13 March 2006 - 07:22 PM
nm, what I posted was for '96- 850s only
Edited by Gregg, 13 March 2006 - 09:01 PM.
Posted 13 March 2006 - 08:55 PM
I have a '95 850 with central locking and alarm system. Nothing on mine flashes when locked or unlocked except for the LED on the dash. So, should the corners flash on mine??? If '95 doesn't flash, why would '94...unless both of ours are defunct?
This may be a different subject but...
Although on mine, sometime the LED won't flash when locked. I found that the back hatch was not getting locked--the doors do. Everytime the hatch didn't lock, the LED didn't flash. Slamming the hatch close harder than usual seems to work. I wonder if you have a similar situation, that is, if you're referring to the LED not flashing, sometimes?
'95 850 Turbo Wagon
Posted 13 March 2006 - 10:23 PM
Mine dosent flash either.
'90 Mazda 626 GT- Modified weekend toy. FE3 DOHC, T3 60 trim. Megasquirt n' spark-E. It runs!
'95 Volvo 855T- For Sale!!
Posted 13 March 2006 - 11:15 PM
same thing happens with my back door. the lock in the hatch stopped working unless i manaully unlocked it.. i just disconnected it and i'll buy a replacement when the time comes.
Posted 14 March 2006 - 12:10 AM
On my 97 855 the signal lights flash when I lock the doors. Perhaps there is a way to enable them. If someone has access to SIDAV maybe there is a procedure in there that tells you how to enable them. Then again maybe that is an option on 97 and newer Ovlov's. What I would like to know is there a way to have the horn sound when you lock the doors?
Corey
Corey
Never accept anything for true which you did not clearly know to be such!
1997 855 AWD 5 speed
Posted 14 March 2006 - 12:56 AM
Corey
Corey
yes there is
QUOTE
850 '96-
Programmable functions via a separate programming box, carried out when the alarm is installed (factory programmed in CAPS):
- Reactivation ON/Off
- Horn alarm Steady/PULSE
- Acknowledge sound On/OFF
- Acknowledge light ON/Off
- Panic alarm ON/Off
Posted 14 March 2006 - 01:23 AM
mine doesnt do anything i have to listen for the locks
This topic is locked
