Oil Leak Around Turbo And Sputtering + Lambda Indicator
10 replies to this topic
#1 NGB
NGB
  • 5,555 posts
Posted 14 March 2006 - 03:21 AM
Ok, so i found a 1998 S70 T5 SE near me that has 99,900 miles, black with tan interior.
Very nice car, aside from the fact that when i went to drive it today i noticed a small amount of oil burning off from the vicinity of the turbo. It seemed that there was oil buildup around the piping that goes over the engine down towards the turbo as well. Any ideas what this could be? My dad said that when the engine was revved the smoke increased, but after the car warmed up and was idling i could no longer see any smoke at all.
Second issue: The car had not been driven in several weeks and when i pulled out of the lot and put the pedal down about halfway, the car sputtered terribly. At this time the lambda indicator on the dash came on and began flashing. After a few more minutes of around town driving the car seemed fine and would hit 5K RPMS no problem. The indicator remained on for the duration of the drive.
Possible causes of this? Also, what exactly does tha lambda indicator light mean? ( I remember seeing a thread about this, but after several searches found only small reference to O2 sensor.)
Any help is greatly appreciated, as i would like to make a decision on this car ASAP.
Thanks!
Nick | 1998 S70 T5 SE | In the works: stuff
Parting: 2004 C70 Vert, 2002 C70 Coupe, 2000 C70 Coupe, 2000 V70R, 1998 V70R, 1999 V70R, 2000 S70 GLT SE
#2 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 14 March 2006 - 03:25 AM
lambda is the canadian version of Check Engine Light?
#3 NGB
NGB
  • 5,555 posts
Posted 14 March 2006 - 03:28 AM
Makes sense, as the car was originally imported into Canada, before coming the states.
It's kinda funny, speedo is in miles per hour, but climate control is in Celsius. blink.gif
#4 James100
James100
  • 874 posts
Posted 14 March 2006 - 03:35 AM
QUOTE(01V70 @ Mar 13 2006, 07:28 PM) View Post
It had a Bilingual owner biggrin.gif French and English
Check Engine Codes OBDI
Stage 0
PCV Pics
#5 andrew_the_fox
andrew_the_fox
  • 704 posts
  • Interests:VOLVOS
Posted 14 March 2006 - 05:29 AM
QUOTE(01V70 @ Mar 13 2006, 10:28 PM) View Post
the temperature should be pretty easy to adjust ace
#6 NGB
NGB
  • 5,555 posts
Posted 14 March 2006 - 05:13 PM
QUOTE(andrew_The_fox @ Mar 14 2006, 12:29 AM) View Post
I never said it would be difficult.
Back on topic though, does anyone have any ideas about the oil leak?
#7 1997850T5R
1997850T5R
  • 496 posts
  • Interests:Volvos, pre ETM
Posted 14 March 2006 - 05:16 PM
Lambda is their word for O2 sensor. There was probably a good bit of buildup in the engine after sitting that long, and it needed to get that sh*t out. I would seafoam it pronto if you can. The oil by the turbo sounds like either a return or feed line that is leaky.
QUOTE (Che_Moderator)
Rocks are hard and bunnies are soft.
I am Kale. I drive A 1997 850R. I love it.
#8 NGB
NGB
  • 5,555 posts
Posted 14 March 2006 - 05:24 PM
QUOTE(1997850T5R @ Mar 14 2006, 12:16 PM) View Post
Leaky lines = big issue, or simple Stage 0 fix?
Also, how much $ am i looking at to replace the O2 sensor?
#9 1997850T5R
1997850T5R
  • 496 posts
Posted 14 March 2006 - 05:39 PM
QUOTE(01V70 @ Mar 14 2006, 12:24 PM) View Post
Leaky lines aren't a Stage 0, but not a huge deal. Similar to replacing brake lines if you've ever done that. And the O2 will depend, check FCP Groton for your specific car as I'm not sure on pricing.
#10 NGB
NGB
  • 5,555 posts
Posted 14 March 2006 - 06:07 PM
Thanks for the help, Kale.
Does anyone have decent diagrams of the turbo area, so i can try to figure out where this oil is coming from.
#11 NGB
NGB
  • 5,555 posts
Posted 14 March 2006 - 09:01 PM
So as i was searching the forums, i found a thread in which people mentioned having oil leaking fromthe turbo into the IC lines, would this oil be visible on the outside of the IC piping, around the fitting?
Would leakage on a car with almost 100K miles be due for a turbo replacement?
