'96 850 Front End Creaking, Clickety Clacking
11 replies to this topic
#1 jjmaxx
jjmaxx
  • 12 posts
Posted 14 March 2006 - 03:24 PM
This just started happening--first it was creaking a little like it needed to be lubed when I would turn hard to the left--the front passenger side would creak. Last few days, it makes the creaking sound when I first take her out, and then it turns into a quick clicking sound when turning, either left or right, and not even at full turn. No vibrations though and had breaks done about a year ago, but the alignment keeps going out after only a month or so and keep getting outer tire wear on the front, equal on both tires.
CV, struts, bushings. tie rods? I am bringing into shop this afternoon but would appreciate any comments from someone who has had similar problem. I am suspecting that this noise has something to do with the alignment problem, but not sure.
Thanks all.
'96 850 GLT
80K miles
Naples, FL
#2 Guest_Guest_cecheatum_*_*
Posted 14 March 2006 - 07:26 PM
Rule of Thumb (but maybe not always)--inside wear-center wear-outside wear, is camber-castor-toein, in your case too much toein.
#3 James100
James100
  • 874 posts
Posted 14 March 2006 - 07:41 PM
QUOTE(jjmaxx @ Mar 14 2006, 07:24 AM) View Post
Thanks all.
Check Engine Codes OBDI
Stage 0
PCV Pics
#4 jjmaxx
jjmaxx
  • 12 posts
Posted 14 March 2006 - 09:30 PM
well just got back and the mechanic did not see anything wrong, so he just lubed the steering stops and said to come back next week if the noise comes back. On the drive home, the creaking sound was gone, but the clicking sound, when the wheel is just about fully turned, was still there--sounds like something is getting ready to snap off. Any further advice would appreciated, and thanks for the tip on the alignment problem, ie the toe in.
'96 850 GLT
80K miles
Naples, FL
#5 850-Turbo
850-Turbo
  • 85 posts
Posted 14 March 2006 - 09:41 PM
QUOTE(jjmaxx @ Mar 14 2006, 01:30 PM) View Post
I'm used to hearing this on Hondas alot and that's the CV joint. When turning with the wheel at lock, give a little gas and see if the noise get worse. You get that familiar "clakity-clakity-clakity-..." sound if it's the CV joint. Jusually, you can't even feel any play in the joint.
'95 850 Turbo Wagon
#6 jjmaxx
jjmaxx
  • 12 posts
Posted 14 March 2006 - 11:09 PM
would the CV generally fail on the 850's if the boot is not damaged?
'96 850 GLT
80K miles
Naples, FL
#7 ericutexas
ericutexas
  • 139 posts
Posted 15 March 2006 - 12:52 AM
QUOTE(jjmaxx @ Mar 14 2006, 05:09 PM) View Post
I know that turbo 850s can eat CVs for breakfast with all that torque, I guess that applies to N/A 850s as well. Every single FWD car that I've had has had failed CV joints at some point or another - consider it a wear and tear item.
-Eric (me)
-Valentin (car)
1996 854T, B5234FT, 100K miles. Anthracite Grey on Grey Leather. K&N Drop-in Filter, Columbas on BF Goodrich Traction T/A. Swedish Flag sticker on trunklid, concealed Valentine One installed. Narva Rangepower low beams. Speedtuning 17PSI ECU, TD04HL-16T turbo from Erievovo.
#8 98XCFxRUpR
98XCFxRUpR
  • 62 posts
Posted 15 March 2006 - 02:06 PM
I had similar sounds and it turned out to be the hub/bearing. Even the mechanic couldn't believe that was it, because it doesn't sound like a typical wheel bearing gone bad, but the noise stopped after he replaced the hub.
1998 XC 106K miles
#9 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 15 March 2006 - 04:05 PM
QUOTE(98XCFxRUpR @ Mar 15 2006, 06:06 AM) View Post
was it a popping/clicking sound? i get that sound, and can't figure it out....some say steering rack, some say CV(new axles i have, though!). I get it when turning over little bumps, or just partially turning at slow speeds.
#10 ericutexas
ericutexas
  • 139 posts
Posted 15 March 2006 - 07:34 PM
I have a clicking sound when my car is parked on a forward incline (car pointing down) and I back up, or when I quickly let off the gas when accelerating, or sometimes when changing gear (but not when turning). Sound like a CV or axle issue to you guys?
-Eric (me)
-Valentin (car)
#11 Patrick.
Patrick.
  • 5,707 posts
Posted 15 March 2006 - 07:52 PM
if you rule CVs out then check endlinks-- those things are always coming loose and causing noises
#12 WhiteT5
WhiteT5
    Sampson
  • PipPipPipPip
  • 4,828 posts
Posted 15 March 2006 - 08:27 PM
QUOTE(prasamin @ Mar 15 2006, 10:05 AM) View Post
Check the boots on the control arm ball joint. I've had a clicking popping sound for a couple weeks and I crawled under the car to find that this boot had torn.
- Sean
