Brake?
9 replies to this topic
#1 Dmsee
Dmsee
  • 6,579 posts
Posted 14 March 2006 - 09:11 PM
i am kind in a bad mood because my brakes killing me
ok i bought a car everything is fine
it was sitting for like 3-4 months
then i drove it for the first day brakes were sqealling BAD!! found out its rear right!
went to shop found out that those metal shims are missing! installed them thought i fixed a problem no noise appears ok turned the rotors and still there is a squeek not all the time but one time squeal other dont
i dont know what to do! mechanic says its something with whole assembly not in pads or rotors
and when i try to brake only with hand brake i still hear noise!
and one more question i was going 50mph down the hill and transmission shifted to 3rd so i was going at 2300 rpm down the hill and after it swithed back IS IT ALLRIGHT??? dry.gif
#2 merlin390
merlin390
  • 2,778 posts
  • Interests:Volvos, Guns, Woodworking
Posted 14 March 2006 - 09:14 PM
first off what brand of pads are you running? second I have found that taking the rears apart and cleaning everything often helps with weird noises also some "pad grease" on the back of the pads and shims helps too.
#3 Dmsee
Dmsee
  • 6,579 posts
Posted 14 March 2006 - 09:15 PM
#4 merlin390
merlin390
  • 2,778 posts
Posted 14 March 2006 - 09:17 PM
*MOST* aftermarket pads squeal. I replaced mine with OEM pads and it only squeals occasionally (usually when I need to take everything down and clean them again)
#5 Dmsee
Dmsee
  • 6,579 posts
Posted 14 March 2006 - 09:27 PM
#6 merlin390
merlin390
  • 2,778 posts
Posted 14 March 2006 - 09:29 PM
I dont see any reason for concern on the tranny. The shift points are based off engine load/throttle postion and the computer "saw" fit for it to be in another gear.
#7 Dmsee
Dmsee
  • 6,579 posts
Posted 14 March 2006 - 09:31 PM
thanks
thanks
#8 pete0r
pete0r
  • 435 posts
Posted 14 March 2006 - 11:10 PM
my car does the same thing. you can almost feel the car sorta.. lurch.. right? with the hill, that is.
1995 855 Turbo - 190k Miles
#9 James100
James100
  • 874 posts
Posted 14 March 2006 - 11:24 PM
QUOTE(Dmsee @ Mar 14 2006, 01:31 PM) View Post
thanks
thanks
So what do you think is the difference? "More Octane?"
Check Engine Codes OBDI
Stage 0
PCV Pics
#10 Dmsee
Dmsee
  • 6,579 posts
Posted 14 March 2006 - 11:58 PM
i am not sure what happened i tested it before couple of times and today it was acting like a beast smile.gif with 93 gas
Edited by Dmsee, 14 March 2006 - 11:59 PM.
