What Is This
Posted 14 March 2006 - 09:50 PM
Posted 14 March 2006 - 10:10 PM
1995 854 NA Auto
RIP - Dad - M.G.T 10/31/42 - 12/03/05 "Press On"
Posted 14 March 2006 - 10:11 PM
You might want to upload your pics to photobucket.com or something similar and insert your images that way...It will be easier to see what you have circled I believe...
Check Engine Codes OBDI
Stage 0
PCV Pics
#4 Guest_AlvinL_*
Posted 14 March 2006 - 10:18 PM
Posted 14 March 2006 - 10:22 PM
16T straight flange for sale 275.00 SOLD
Posted 14 March 2006 - 10:38 PM
looks like i have mess with the vacuum tubes.
are there any good diagrams that explane where all vacuum tubes should be conected
so whot abaut this end that stiks out?
Posted 14 March 2006 - 10:44 PM
Posted 14 March 2006 - 10:49 PM
Edited by James100, 14 March 2006 - 11:49 PM.
Stage 0
PCV Pics
Posted 15 March 2006 - 12:47 AM
+1 ... I did this and broke the hard plastic pipe and had to do a complete PCV job. The circled part is part of the PCV system - the larger one connects back to the oil trap and it cycles crankcase fumes back into the fresh air intake hose. The smaller one, if I remember correctly, is connected to the port on the left side of the intake manifold so that it can provide vacuum to the device that the two hoses connect to (not sure what it's called) ...
It's common for the vacuum elbow on the left side of the intake manifold will be broken, and in that case, just run the small hose to an open port on the vacuum tree.
-Valentin (car)
1996 854T, B5234FT, 100K miles. Anthracite Grey on Grey Leather. K&N Drop-in Filter, Columbas on BF Goodrich Traction T/A. Swedish Flag sticker on trunklid, concealed Valentine One installed. Narva Rangepower low beams. Speedtuning 17PSI ECU, TD04HL-16T turbo from Erievovo.
Posted 15 March 2006 - 12:58 AM
I did a splice job on mine by getting about 2" of a larger hosing and 2 hose clamps...You shove the larger hose over the PCV piping at the break...They sell larger oil resistant PCV hosing at Pep Boys
Edited by James100, 15 March 2006 - 01:00 AM.
Stage 0
PCV Pics
Posted 15 March 2006 - 12:59 AM
'91 240 Sedan- Sold 4/21/09
Posted 15 March 2006 - 03:45 AM
+1
I just ran a standard vac line w/ the cloth insulation around, since it pretty much sits on the fuel rail: HOT!
Don't bother with the OEM stuff.
Posted 15 March 2006 - 05:29 AM
1997 855 AWD 5 speed
#14
Posted 15 March 2006 - 03:24 PM
I second that. I went through all the vac lines on the XC and replaced what rubber elbows I saw with the 3.5mm silicone line that I had. Looks a little odd but hopefully I won't have to mess with them again.
'95 855 GLT
'83 245 DL
Your LPT does what?
#15
Posted 15 March 2006 - 05:56 PM
my gauge was conected to air tube and that breathing one to where the gauge shoukd be. now \I changed back. not much diference by driving unles gauge is woorking now
This topic is locked
