Power Steering Making Loud Noise
8 replies to this topic
#1 UberV70
UberV70
    do the evolution
  • 2,215 posts
Posted 15 March 2006 - 09:06 PM
Something very fishy is happening with my power steering. Whats happening is really whenever i crank the wheel and make a turn, weather i'm parking, or making a right or left hand turn at a stop sign or stop light i get a rather loud mechanical moan. It sounds like the power steering motor is really straining and i can even feel that its a bit harder in the turning of the wheel. I checked my fluid level and it seems to be up, as for the colour, i'm not really sure how its supposed to look but its sort of orangey. Would changing my fluid solve this problem, or do i have to get a new power steering motor / whatever it takes?
Any help is appreciated.
My name is Adam and this is My Old and Un-Updated Cardomain Page
#2 NataSS Inc
NataSS Inc
  • 336 posts
Posted 15 March 2006 - 09:17 PM
If the fluid level is good then the bearing in the pump is going out on you. A pump swap wont be tough. Just set aside some time and get'er done. Check wrecking yards before going to the stealership. Some wrecking yards will offer 30-90 and sometimes 1 year warantees with the parts they give you.
I have a leaki in my stearing rack somewhere and have to constantly fill the resivoir. I'd be a hell of alot happier if it was the pump going. For me it looks like I have to repalce the entire steering rack.
IPB Image
'97 850 T-5
Charlie Hotel India Mike Papa
Lou Gillotti: "Its a game of inches and ounces. And I'll find every inch and every ounce I can"
#3 Crabolsky850
Crabolsky850
  • 279 posts
Posted 15 March 2006 - 09:25 PM
QUOTE(NataSS Inc @ Mar 15 2006, 04:17 PM) View Post
Right you are. Ebay for the pump. Although someone posted a quick fix using magnets about a week ago.
I actually just replaced my steering rack yesterday. Not cheap, but worth doing.
I noticed that my power steering pump was making noise so I checked the levels and it was empty.
Turns out it was a leaking rack. FCP $235 for the rack plus a $150 core charge. 3 hours labour plus an alignment.
<b>Ben</b>
~1995 850GLT- 140,000 miles, some cosmetic additions but pretty much stock
~1999 V70- 105,000 miles
#4 ericutexas
ericutexas
  • 139 posts
Posted 15 March 2006 - 09:29 PM
$59 at http://www.erievovo.com/specials.asp. Haven't done business with them personally, but I've heard nothing but good things about them and a lot of the guys here have gotten turbos from them with good results. They actually offer a free lifetime warranty on many of their used parts, but I'm not sure which parts this applies to. Try changing the fluid first, though - any type of ATF will do. Take a turkey baster and take out all the fluid in the reservoir, top it off with new fluid, drive it around a while and repeat the whole process 2-3 times to change out the fluid.
-Eric (me)
-Valentin (car)
1996 854T, B5234FT, 100K miles. Anthracite Grey on Grey Leather. K&N Drop-in Filter, Columbas on BF Goodrich Traction T/A. Swedish Flag sticker on trunklid, concealed Valentine One installed. Narva Rangepower low beams. Speedtuning 17PSI ECU, TD04HL-16T turbo from Erievovo.
#5 UberV70
UberV70
    do the evolution
  • 2,215 posts
Posted 15 March 2006 - 10:40 PM
yeah the fluid levels seem to be allright, but i will check again when i've let the car sit for a few hours just to make sure. And if it is indeed the pump - there are a few volvo wreckers around and i'm sure i can get ahold of another one and make a day out of it. Thanks for your help!
#6 James100
James100
  • 874 posts
Posted 15 March 2006 - 11:04 PM
One angle to look at is this:
I had a problem similar to yours and this cured it....
Use a turkey baster (.99 at 99 cents store) and magnet ($6 OSH) methood ...Use baster to remove fluid ..do it several times....Put the magnet in with plastic tie strap..keep strap away from hole....(99cents store or auto store) ..see if it goes away in a few days or a week..
Cleaning power steering fluid with a magnet
OSH is Orchard Supply Hardware...Hardware store or maybe Home Depot for magnet
Oh yea.....if it works for you post back......it worked on my car but this mechanical moan I had only happened when turning as I was backing out of my garage and then again went I went forward as I straightened the wheel.....It did not happen at stop signs so your condition sounds more severe
Edited by James100, 15 March 2006 - 11:51 PM.
Check Engine Codes OBDI
Stage 0
PCV Pics
#7 Karlson
Karlson
    Vodka Lover
  • 7,142 posts
Posted 15 March 2006 - 11:17 PM
any bubles inside? did u search before post?
1996 850R... gone, but not forgotten
#8 UberV70
UberV70
    do the evolution
  • 2,215 posts
Posted 17 March 2006 - 07:45 PM
I'd just like to follow up to this post and say that i let my car sit for a whole day just to let things settle inside. I checked the power steering fluid again and it was definitly low - wasent even touching the dipstick blink.gif . Anyways i went out and bought some automatic transmission fluid and topped er up, drove around for a little and the noise seems to be gone.
Now the next thing to figure out is where did the fluid go that WAS in there...... hmmmmmmmmm
#9 johnkalajian
johnkalajian
  • 4 posts
Posted 19 March 2006 - 06:22 PM
If your rack seal is leaking, the "missing" fluid may have leaked into the steering boots on the ends of your steering rack. Check your boots for fluid.
