Heated Seat Wiring Diagram Request?
#1 Matts 850 GLT
Matts 850 GLT
  • 308 posts
Posted 16 March 2006 - 02:13 PM
Hi
I just repaired my passenger side heated seat with a new thermostat. But my drivers side still not working.
Have put a new thermostat on it and no heat.......I checked the wiring under the seat but wasn't sure which color is for what.
If anyone has a wiring diagram for heated seat please can I see it??
Much appreciation
1997 855 T5 auto
#2 Matts 850 GLT
Matts 850 GLT
  • 308 posts
Posted 16 March 2006 - 07:09 PM
[attachment=607:attachment]DUH blink.gif
Just wanted to let you know I hit search and came up with this.
1997 855 T5 auto
#3 coolwheels
coolwheels
  • 1 posts
Posted 27 March 2006 - 01:52 AM
Here's another diagram of the seat heaters. The connecter link will show what the various connectors under the seat look like. The table for that is below.
C/CE Connector, 2-pin, heated front seat, left
C/CF Connector, 2-pin, heated front seat, left
C/CG Connector, 2-pin, heated front seat, right
C/CH Connector, 2-pin, heated front seat, right
3/91 Switch, heated front seat, left
3/92 Switch, heated front seat, right
7/43 Thermostat, left front seat
7/44 Thermostat, right front seat
9/3 Backrest heater pad, left front seat
9/4 Backrest heater pad, right front seat
9/5 Seat heater pad, left front seat
9/6 Seat heater pad, right front seat
11/26 Fuses
24/1 Connector
Instrument panel harness - firewall harness
24/2 Connector
Engine compartment harness - firewall harness
24/3 Connector
Firewall harness - left door sill harness
24/4 Connector
Firewall harness - right door sill harness
24/7 Connector, 14-pin Firewall harness - tunnel harness
24/21 Connector, 6-pin
Left door sill harness - left front seat
24/22 Connector, 6-pin
Right door sill harness - right front seat
31/15 Ground point, A-pillar passenger side
31/44 Ground point, engine compartment (ground point, battery - body)
31/47 Ground point, left cross member
31/48 Ground point, right cross member
