Oil Cooler Line Leaking..help!
#1 Guest_Guest_jrsmith70_*_*
Posted 16 March 2006 - 05:23 PM
My 1998 S70 has developed a oil leak at one of the oil cooler lines. It looks as if it is comming from where the retainer clip is located oposed to the crimp site. Is there a failed O ring that could be replaced or is it time for a new line?
#2 grocerygetter
grocerygetter
  • 435 posts
Posted 16 March 2006 - 06:42 PM
Probably an O ring, pry the clip off and see if it is bad or just replace for the hell of it, shouldnt run you more than a couple bucks. I replaced both my oil cooler lines about two years ago because I was leaking where it was crimped, that was not a fun job.
1997 854 T5 :: TME ECU :: TME Cat-back Exhaust :: 17x7.5 Canistos :: Maxxis MA-Z1 215/45ZR17 :: 850R Front Spoiler :: Samco Hoses :: K&N ::
2004.5 S40 2.4i :: Completely Stock ::
2008 Porsche Boxster
#3 salesdeity
salesdeity
  • 25 posts
Posted 18 March 2006 - 01:12 AM
Why was the job so hard? And on the end that attached to the oil filter housing, is there an O-Ring that goes in there? I have two new lines I wanted to install this weekend but there are no o-rings on those ends. What do they look like? Anyone know the size so I can get locally tomorrow since dealer is closed?
1996 Volvo 850 T5
IPD ECU and Exhaust
100K miles
Best G-Tech Times
0-60 5.79
1/4 14.10 @ 105.90 mph
#4 Guest_Guest_*
Guest_Guest_*
Posted 18 March 2006 - 10:07 PM
ttt
