Towing
#1 jnet
jnet
  • 32 posts
Posted 16 March 2006 - 09:56 PM
Is it possible to get a tow package for the 850? I was just wondering if i will be able to tow my jetskis.
#2 Boomin850
Boomin850
    Socal Rod Bender
  • 4,486 posts
  • Crew:SCC
Posted 16 March 2006 - 09:59 PM
Yea, its possible...I don't think more than a couple people have it on here...I think its made my Thule or something like that
Read these
http://volvospeed.com/vs_forum/index.php?s...=towing+package
Oh and next time try and search it...its easy enough
lolwut
#3 mbsl98
mbsl98
  • 697 posts
  • Interests:cars, boats, skiing, family, travel
Posted 16 March 2006 - 10:15 PM
No problem. Really a question of how much your trailer plus equipment will weigh. The 850 has a towing limit of about 3,300 pounds, if trailer has brakes, and I believe 1,100 pounds without brakes. for lighter loads, you should be fine with an after market hitch such as U-haul, Drawtight, etc. They all look pretty much the same, and install into pre drilled holes that Volvo puts in all of its cars. No special tools or skill needed, but a set of ramps or jack stands to get teh rear up a little give you more room to move around under the rear end. I think it took me about 30 minutes the last time I put one of these on (only three bolts, and nothing else to do). If you are pulling more to the higher end of load range, I much prefer teh Volvo factory hitch. It is much more substantial, and is secured with a total of 16 separate bolts, all again into pre-drilled holes. It also is a DIY job, but takes longer due to the number of bolts and the need to access a couple ofo teh holes from inside teh trunk. Wiring kits can be after market of Volvo also, and no big deal to wire into car.
Used hitches, particularly the after market ones, are often on Ebay, usually under $100. Volvo is more rare, and more expensive ($150+?).
Mike Sullivan
Currently: '09 XC70 T6 (3k); '95 855T (128k),'84 MB 380SL (94k summers only).
Kids cars: '98 S70 T5M (130k), '98 V70 M (116K).
Prior Volvo's: '85 744 (256k), '86 245 (165k), '86 245 (195k), '88 745 (208k), '91 745 (196k), '93 965 (147k), '95 855 NA (190k), '98 XC (98k), '07 XC70 (40k).
