QUOTE(aixgelo78 @ Mar 16 2006, 04:28 PM)
hey guys...new to the forum...but been into modding for 10 years now... i purchased a 94 850 glt wagon as a beater. the car has not started in a while when i bought it and i am about knee deep into this car as is.
now the issue...
2.3T auto trans
no check engine light when the key is in the on position (from my experience from audis that is a sure sign of a dead ecu)
no spark
the car cranks good
tdc is good
reference sensor is good
cam angle sensor is good
ignition module is good
could not get any fault codes by checking the fault code thing by the ecu, checked pin 2 and 6, but I am not getting any codes whatsoever from it
anybody had an ecu go bad on them?
TIA chris
if you arent at least getting a 1.1.1 from the ecu in 2 especially, someting is very wrong. check the other pins as well. if no 1.1.1 from tranny, cruise, etc, just sell the car (kidding)
make sure the ecu is locked into place in it's box. no led at the test port and no check engine light makes me pretty sure it's either not plugged in right, or totally fried.
