Question About '96 850 Expansion Tank And Sensor Connection
#1 1sciroccofahrer
1sciroccofahrer
  • 77 posts
Posted 17 March 2006 - 04:36 PM
I have had no luck in discerning where the coolant level sensor (that goes in the bottom of the expansion tank) connects on the end that doesn't reside within the tank. I assume that something should be connected to the port, but nothing obvious sticks out. Any help would be greatly appreciated. Thanks smile.gif
#2 James100
James100
  • 874 posts
Posted 17 March 2006 - 05:13 PM
QUOTE(1sciroccofahrer @ Mar 17 2006, 08:36 AM) View Post
On the other side of the tank is a plastic slot the connector port should be there...It slides into the slot ..If its not in the slot just look around you will find it....
Check Engine Codes OBDI
Stage 0
PCV Pics
#3 1sciroccofahrer
1sciroccofahrer
  • 77 posts
Posted 17 March 2006 - 05:33 PM
