S70 Spark Plugs
Posted 17 March 2006 - 06:03 PM
Posted 17 March 2006 - 06:32 PM
I personally don't put anything on the threads of my new plugs, I'm not sure if anyone else would recommend it.
Yeah i got 5 OEM plugs from FCP Groton so i assume theyre gapped correctly. And i wasnt planning on putting anything on the threads, just wondering if there was any advantage to it or something. But if not then thanks i appreciate it.
Posted 17 March 2006 - 06:58 PM
Posted 17 March 2006 - 07:12 PM
You will want to have this handy and use it regularly on such things as the spark plug cover bolts, thermostat housing bolts, fuel rail bolts, throttle body bolts...get the idea? With an all aluminum motor, you need to be careful.
Definitely check the plug gap. They should come gapped already but even if the gap spec is what you want, check them anyway. Takes like 20 seconds and you'd be surprised at how often you find they are off.
Posted 17 March 2006 - 07:24 PM
I check everytime, and they are off 1/2 of the time by a bit.
Posted 17 March 2006 - 08:33 PM
Is there any particular kind of anti-seize i should buy? or does it all do the same thing?
Posted 17 March 2006 - 09:36 PM
Posted 17 March 2006 - 11:26 PM
OE spark plugs are great, but I just put in the 17psi ST chip into my car and am running Bosch FR7DC plugs from AutohausAZ.com, but I got a FR7DCL or something like that in the mail. They have dual electrodes and a copper center, and gapped to 0.24, they run very well with the increased boost. Are the Volvo plugs 2 or 3 electrode designs?
-Valentin (car)
1996 854T, B5234FT, 100K miles. Anthracite Grey on Grey Leather. K&N Drop-in Filter, Columbas on BF Goodrich Traction T/A. Swedish Flag sticker on trunklid, concealed Valentine One installed. Narva Rangepower low beams. Speedtuning 17PSI ECU, TD04HL-16T turbo from Erievovo.
Posted 18 March 2006 - 12:26 AM
If anybodys looking for that Bosch plug they sell them at Pepboys and the price out here (Los Angeles) is .99 cents all the time
Edited by James100, 18 March 2006 - 12:27 AM.
Check Engine Codes OBDI
Stage 0
PCV Pics
Posted 18 March 2006 - 03:24 AM
Well im not much for technical talk but i guess its only 1 electrode, its got a copper tip i think??, and 1 metal piece running off the side of the plug to up above the electrode. Also, i have been to sears auto center, home depot, and ace hardware and they have no idea what anti-sieze is. Where else can i get it from? like a pep-boys or autozone?
Edited by 98WhiteS70, 18 March 2006 - 03:26 AM.
Posted 18 March 2006 - 03:39 AM
Yes both stores.....
Edited by James100, 18 March 2006 - 03:51 AM.
Stage 0
PCV Pics
#14
Posted 18 March 2006 - 03:46 AM
'91 240 Sedan- Sold 4/21/09
#15
Posted 18 March 2006 - 07:56 AM
+1 to both, I find it to make a big difference when doing maintenence later on and such. Also helps all of the parts to last longer. Except the latex gloves part... Geez, all you Volvo guys don't like to get down and dirty. I work on my car laying in the dirt!
I am Kale. I drive A 1997 850R. I love it.
#16
Posted 18 March 2006 - 03:08 PM
#17
Posted 20 March 2006 - 06:52 PM
Any auto parts store will have anti-seize.
This topic is locked
