I have a '95 850 sedan needs to have the driver's side outer boot replaced. Anyone have any shortcut ideas on how to do this procedure?
I've ordered the parts from FCP and plan to do it next weekend.
Thanks in advance
Cv Boot Installation
Started by xraybob, Mar 17 2006 07:21 PM
6 replies to this topic
Posted 17 March 2006 - 07:21 PM
2002 2.4T S60
Posted 17 March 2006 - 10:13 PM
What exactly did you order from FCP? Did you happen to order an entire rebuilt axle?
Alex
Posted 17 March 2006 - 11:10 PM
No, all I ordered was the boot replacement kit. It does the inner and outer boots has the clamps and grease.
My boot just recently split on the outboard side and grease still remains.
Thanks, Bob.
Thanks, Bob.
2002 2.4T S60
Posted 18 March 2006 - 12:29 AM
you are going to need a special pair of pliers to squeeze the clamps together. you need something besides a tie-rod end fork to seperate the tie-rod ends or you will probably tear their boot. it is not that hard go slow put everything back right.
Posted 18 March 2006 - 02:57 AM
The pliers for the clamps are called Oetiker pliers, and are available from any good parts store or on ebay. You can do it without the special pliers but you run the risk of damaging the clamp. You don't need to separate the tie rod end to remove the axle. See the repair section of this forum for wheel bearing removal and it will give you most of the information you need to remove the axle.
Now for the fun part. After you get the axle out and on the bench, you'll need to separate the axle shaft to change out the boots. There's a clip which holds the axles together which is challanging. If it proves too challanging, just call up raxles.com and get a rebuilt unit. Not a bad way to go.
'98 S70 GLT
Posted 18 March 2006 - 03:07 AM
I replaced the boots without seperating the axle from the hub. What a sad way to do it but when you don't know what your doing you just do it.
#7 Guest_AlvinL_*
Posted 18 March 2006 - 02:10 PM
Don't be intimidated but here's the thing to be ready and be prepared for. Once you got the axle out and on the bench, the hardest part is opening up the circlip and trying to separate the shaft. I used my Black and Decker workbench to hold the axle. This is so you can clean off the old grease to replace with new boots. Cut of the outer boot and wipe up the grease so you can see and work on that circlip. I followed my Haynes manual. Separate the clip and tap away. When it has moved apart enough, and the clip is not holding it in anymore, go ahead and bang away using a drift punch. Be careful to hit only the center splined part. Clean off the old grease and replace with new. If it's like the dealer-bought kit, the outer grease is graphite color and the inner grease is white.
The best part about this is saving some money and knowing you did a good job. It's only your time.
This topic is locked
