Power Steering Leak?
#1 involvod
involvod
  • 56 posts
Posted 17 March 2006 - 07:33 PM
blink.gif It appears that my '94 Volvo NA power steering is leaking from under the reservoir cap.
On the top of the container unit, there is fluid that is very sandy or granular.
When I remove the cap, the power steering fluid is almost at the refill mark. This situation has been for at least a month, but I have yet to add any fluid.
Should I get another cap from the dealer? I called them to see whether they sold a rubber washer separately, but you must buy the cap with the measuring gauge and rubber washer.
Will buying a cap do the trick?
#2 BeachRat
BeachRat
    Team GKT
  • 2,761 posts
Posted 17 March 2006 - 07:52 PM
I have the same issue. The sand/granular stuff is just dirt from the air moving through your engine bay mixing with the seeping fluid. Unless you can find a similar rubber washer at Home Depot or something, you need to just replace the cap.
#3 James100
James100
  • 874 posts
Posted 18 March 2006 - 01:46 AM
QUOTE(involvod @ Mar 17 2006, 11:33 AM) View Post
Buy the new cap and try it out....Post back here if it works....Its probably got a hair of a warp to it because its old....
Edited by James100, 18 March 2006 - 04:24 AM.
Check Engine Codes OBDI
Stage 0
PCV Pics
#4 Guest_Guest_involvod_*_*
Posted 19 March 2006 - 02:12 AM
smile.gif Thanx for the replies!!!
I ordered a reservoir cap from the volvo dealer parts department. It will be available this Tuesday.
The idea of the granular particles coming the bay area is very sound. I had purchased a magnet from one of the auto parts franchisers that has an antenna aerial extension attached to it. When I dipped it in the reservoir several times, nothing attached itself to the magnet. Perhaps, that explains it.
