Connecting Rods
14 replies to this topic
#1 josh_S70GLT
josh_S70GLT
  • 443 posts
Posted 17 March 2006 - 09:37 PM
it is possible to change the connecting rods without removing the engine/transmission from the car?
also, what needs to be changed when changing the rods besides screws? do the bearings need to be renewed too?
98' S70 GLT
EST Intake, 16T @ 15psi, Forged Rods, Speedtuning ECU, iPD HD TCV, iPD Cat-Back, Strut Brace, Bilstein HDs, iPD Grille, Jewel Headlights, 17" Canistos, 215/45/17 Kumho ASX Tires
#2 TheMan5952
TheMan5952
  • 628 posts
Posted 17 March 2006 - 09:43 PM
I would get new bearings as well since your in there. I honestly haven't been under my volvo enough to see if you can get to everything under the car.
-Joe- '02 S60 T5
Ron Paul in 2008
Need a New interior? Local NW shop Jack's Upholstery
#3 JoshV70
JoshV70
    Brody
  • 4,542 posts
Posted 17 March 2006 - 10:03 PM
You can change rods by removing the head and oil pan from the engine.
#4 tenn850
tenn850
  • 428 posts
Posted 18 March 2006 - 04:13 AM
It is possible to remove the lower part of the rod and remove the main bearings from the oil pan area with engine in the car. Remove the lower part by undoing the bolts and remove the lower journal, then introduce a small screw driver and turn the upper journal to turn 180 deg. to come to lower side and remove them too.
But the upper part of the con. rod is connected to the piston by the pin. And I do not think you can lower the piston to the point that you can remove the pin out! ohmy.gif The crankshaft is connected to the flywheel and to the tranny so it can't be removed this way.
In all you can replace the bearings and the lower part of the con. rod only. If the rod is bent or the crank surface is damaged the new bearings will be damaged soon too.
You can replace the rods, pistons, rings etc by removing the head cylinder and the oil pan. But if I had to do this job I would just remove the engine and tranny out for a complete overhaul. blink.gif It is too hard on the back to do it with engine in the car. unsure.gif
Edited by tenn850, 18 March 2006 - 04:14 AM.
95 850 GLT
#5 josh_S70GLT
josh_S70GLT
  • 443 posts
Posted 18 March 2006 - 04:31 AM
i'll have to see how far I get this summer
#6 850-Turbo
850-Turbo
  • 85 posts
Posted 18 March 2006 - 09:04 AM
QUOTE(josh_S70GLT @ Mar 17 2006, 01:37 PM) View Post
I gotts ta know, why do you need to change the connecting rods?blink.gif Is it making noises?
'95 850 Turbo Wagon
#7 josh_S70GLT
josh_S70GLT
  • 443 posts
Posted 19 March 2006 - 04:38 AM
yeah, it's got a knock to it on the bottom end, this was after I refitted my MBC that I thought was still adjusted correctly...apparently not
I am not driving the car, just using my jeep until I get to taking everything apart
#8 850-Turbo
850-Turbo
  • 85 posts
Posted 19 March 2006 - 06:58 AM
QUOTE(josh_S70GLT @ Mar 18 2006, 08:38 PM) View Post
Well, that is unfortunate. But I don't think you need to replace the whole connecting rod. Just the bearings. And as a rule of thumb, never replace connecting rod caps and not the rod. I don't think you can buy them separately, though, anyway.
Another important point is not to mix up the caps. Unless I'm wrong, they're matched pairs, (rods and caps).
One more thing to note (bad news) is that, when rod bearings go out, the crank journal, corresponding to the bad rod, tend to get damaged. So most likely you'll need to remove the crankshaft and have the journals turned and you'll need to get oversize rod bearings. sad.gif
That means, you'll also be doing the timing belt R&R and at the least, separate the transaxle and remove the flywheel/flexplate. You probably can't do this without actually removing the trans completely. sad.gif
If you do find that you need to do the crank job, I would just pull the motor/trans together and work outside, or even do a rebuild or replace the motor.
Another possiblity for the knocking noise. I had an old Ford 6-cyl in the 80's and it developed knocking sounds on the bottom end. Somehow, I figured out that it was a crack in the flexplate at one of the mounting bolt holes. This is probably rare, though.
Did you use a stethoscope to determine that it's the con rods?
By the way, what is MBC?
'95 850 Turbo Wagon
#9 jross
jross
    Mad Scientist
  • 3,729 posts
Posted 19 March 2006 - 07:26 AM
QUOTE(850-Turbo @ Mar 18 2006, 10:58 PM) View Post
MBC = manual boost controller
I second checking that noise with a stethoscope.
If you bent a rod, you're probably looking at some damage either on the cylinder walls or the crank - that's the lovely knock noise you're hearing. I'd definitely just plan to remove the engine for an overhaul at that point. You can do it all in-car, but you're talking about a serious pain in the ass doing it that way. If you have cylinder wall or crank damage, you'll have to pull the block anyways.
#10 BlackT5
BlackT5
    NWC Rod Bender
  • 5,769 posts
Posted 19 March 2006 - 04:21 PM
The noise from my bent rods came from the top of the rod hitting the crank counterweight. You could drop the pan and look for any visible signs of damage. Even pull off the rod caps and check the bearings.
Like the others have said, it will be a serious pain in the ass to replace the rods with the motor in the car. What would really suck is if you missed something, put it all back together only to find that it's not fixed properly.
Some pics of what to look for..
and here is where my rods were hitting..
you've probably seen this one before, i've posted it many times
good luck man. are you thinking of upgrading the rods?
1998 S70 T5M
#11 josh_S70GLT
josh_S70GLT
  • 443 posts
Posted 19 March 2006 - 10:01 PM
yes, I'll get the forged rods from VMS
if I cannot change them with the engine in then I will plan on getting the pistons and rod set, bore the engine and grind the crank.
#12 Swedish Mike
Swedish Mike
    bow to the swede
  • 2,374 posts
  • Interests:Girls, cars and JD.
Posted 19 March 2006 - 10:23 PM
Normally the crank handles rod bending well, if you turn off the engine in time you only need new rods and bearings.
/Mike
#13 SIAMBLUE
SIAMBLUE
  • 250 posts
Posted 20 March 2006 - 12:27 AM
Hi pal, I did my rods today too at Avon Park raceway, finally had the car back up and running well, and for some stupid moment i took the MBC off and fitted the standard BCS, 3K revs and that was it, slight stutter and a very loud noise,
Car is at the garage now waiting to be stripped down, and will be fitted with H rods,
fastest time of the day was Stuart of SW Auto's put in a 13.02 quarter mile, ohmy.gif
Gary
1998 V70R FWD manual in Saffron, 19t, Rica custom tune, THS intercooler, CDA, 63mm throttle body, RIP kit, 3" angled DP with race cat & 3" stainless exhaust system, Cooling mist WI 100% meth, KAD 6 pots with 330mm x 30mm AP discs, DS3000 pads.
Give blood tease an Akita...
#14 jross
jross
    Mad Scientist
  • 3,729 posts
Posted 20 March 2006 - 03:28 AM
QUOTE(josh_S70GLT @ Mar 19 2006, 02:01 PM) View Post
I've got drop-in forged setups, no machining required. Let me know if you're interested. SPM H-beam rods and custom Venolia pistons - we can even match it to your existing cylinder bore if you want.
#15 ms007
ms007
  • 396 posts
  • Interests:boating
Posted 20 March 2006 - 03:40 AM
QUOTE(BlackT5 @ Mar 19 2006, 11:21 AM) View Post
Like the others have said, it will be a serious pain in the jerk to replace the rods with the motor in the car. What would really suck is if you missed something, put it all back together only to find that it's not fixed properly.
Some pics of what to look for..Was the compression lower the cyl with the bent rod???
96' 850R - Duelstage MBC - 18T - White Injectors - 17psi RICA flash - Phantom II gauges - 3" J downpipe -3" mandrel bent cat back - dynomax- O2 wideband-
16T straight flange for sale 275.00 SOLD
