Power Loss
Posted 18 March 2006 - 02:56 AM
If not has anyone ever experienced this power loss before?
Its definatly not fuel cut cause I hit that before and its no where near as harsh.
Posted 18 March 2006 - 04:06 AM
2.4
Straight Flanged 18T, S60R exhaust manifod, ZTR 3" downpipe/cat, 3" custom catback exhaust w/ Borla XR-1 muffler, 475cc S60R Injectors, Walbro 255 lph pump, FMIC + rerouted 2.5" aluminum piping, Genuine HKS SSQV, Kaphlenke blanking plate, Rica ECU, Bosch coppers .025 gap
Dawe's MBC and A/F ratio meter, Hosetechniques vacuum lines, OBX boost gauge and strut brace, QBM Cam tool, Magnecor 8.5mm
Pirelli P Zero Nero 225/45/17, Bilstein HD struts/shocks, Vogtland 1.4" springs, QBM Endlinks
Brembo cross drilled, Greenstuff pads, FCP Groton SS brake lines, Rebuilt ABS module
Black projector headlights, Debadged, Platinum tint, Black mesh grill, Calipers painted to match Greenstuff pads, "VOLVO" caliper decals
13.8@101@20PSI with BAD conditions and before many mods
Posted 18 March 2006 - 04:55 AM
But I think that the fuel rail should still hold pressure after shutdown, maybe bleed off eventually but not right away
Posted 18 March 2006 - 06:38 AM
Posted 18 March 2006 - 07:50 AM
Well, I can't disagree as I'm not sure about the pressure on our cars but... Mine doesnt have any noticable fuel problems, but when I bleed the rail to remove lines to do maintenence I can tell its much lower than 40's. My former car had the same kind of bleed cap on the fuel rail, and would shoot fuel quite powerfully and at some distance when bled. The bleed off on my car only seemed to be at about 5-10psi when I bled it.
I am Kale. I drive A 1997 850R. I love it.
Posted 18 March 2006 - 08:28 AM
I think the fuel pressure comes from the fuel pump. The FPR only regulates the pump pressure down to managable level. Sounds like yours is regulating.
One possibility might be that at high loads, the pump may not have the volume to keep up with the demands.
Are you just not able to rev above 4K RPM, even sitting in park? How does it perform going up a hill? Would it have difficulty climbing even at 3K?
Important question is this: when you loose power, is the engine running smoothly, or is it misfiring/sputtering and rough? Roughness may indicate fuel or ignition problem. If smooth, this may indicate plugged-up exhaust.
Posted 18 March 2006 - 03:42 PM
Our cars use a 3 bar regulator, so 42 psi is about right. Do what I said and see what happens.
Posted 18 March 2006 - 05:15 PM
it keeps climbing in rpm's but slows down drasticly
Posted 19 March 2006 - 07:34 AM
Are you saying that the engine RPM keeps going up, but the speed of the car won't go up? If this is true, your clutch is slipping if you have manual trans, or in the case of automatic trans, all I can say is transmission rebuild. Sorry, I'm not familiar with automatic transmissions.
But if what I'm understanding is not what you're saying, then I'm confused.
by the way, you can't have power loss and RPM climbing at the same time, so are you ,maybe, mistaking power loss with loss of speed?
Posted 19 March 2006 - 08:03 AM
Rpm's do keep climbing and speed increases. Its that once the rpm's get to a certain point the car dosen't slow down, it just stops pulling hard
I'll try to get a camera tomorrow and take a short vid
Edited by 850T_Wagon, 19 March 2006 - 08:05 AM.
Posted 19 March 2006 - 03:23 PM
actually you can.
(cue hypothetical situation)
if it takes 10 minutes to get from 4000 rpms to 5000 rpms, but only 30 seconds to get all the way to 4000, he's experiencing power loss. at least when compared to almost any other 85xT
if it's running smoothly but out of steam, and not making an weird noises, i'm going to back up the plugged exhaust theory.
normally this would be easy to test, but since the cat is integrated into the downpipe it's going to be difficult. the cat is likely what is wrong, if it's a plugged up exhaust.
one thing you can do to test this is unhook the rest of the exhaust and look into the back end of the cat to see if it's broken up.
1998 Jetta TDI
www.savetheinternet.com
Posted 19 March 2006 - 04:55 PM
I'll check that today, the cat was changed (so i was told) 500 miles before i purchased the car. It has the factory downpipe but the stock cat was cut off and a replacement (shorter) cat was put in
Maybe it just had trouble keeping up with the flow now that i'm chipped and since changing to samco's no longer losing boost
Posted 20 March 2006 - 06:24 AM
Well, am I sh*t faced!
#14
Posted 20 March 2006 - 04:08 PM
it is possible that the chip increased flow and heat through the exhaust enough that if they used a cheap cat it killed it quickly. i drove a turbo rx7 for a while and basicly beat the crap out of that car for months, but only when i put a downpipe in, and increased the boost 5 pounds, did the cat die. within 150 miles. it went from pulling on LT1 camaros to getting stomped by geo metros. pretty dramatic difference. so i just gutted the cat and that was that.
1998 Jetta TDI
#15
Posted 20 March 2006 - 11:29 PM
Drove the car with the windows down and in first gear the rpm's climb to about 3k or 3500 and then it stops pulling as hard and right before the car shifts I can hear popping in the exhaust.
Could it be spark blowout with them symptoms?
#16
Posted 21 March 2006 - 02:59 AM
Try this test: in Park, have someone rev the engine and you feel the exhaust at the tail pipe with your hand. The exhaust should have some good pressure against your hand. If it feels whimpy, you may still have some blockage in the pipes.
#17
Posted 21 March 2006 - 03:04 AM
did that too, good pressure at the tail pipe
After hearing the popping in the exhaust today I am thinking it may be ignition related
it almost sounds like I'm shootin flames
#18
Posted 21 March 2006 - 06:06 AM
I have the exact same problem.... ODB 2 says it's o2 sensors
#19
Posted 21 March 2006 - 06:33 AM
1998 Jetta TDI
#20
Posted 21 March 2006 - 04:31 PM
Boost is fine from what I can tell (factory gauge)
This topic is locked
