Water Pump Replacement - How Difficult?
1 reply to this topic
#1 raymondjiii
raymondjiii
  • 90 posts
Posted 18 March 2006 - 03:42 PM
Does anyone have any notes or experience on doing this job? Thanks.
98 V70 AWD
#2 pfeener
pfeener
  • 950 posts
Posted 18 March 2006 - 04:54 PM
The water pump is easy, but usually you would do the timing belt and perhaps the idler and tensioner at the same time you do the pump. Bottom line: if you have the capability to do the timing belt the water pump will be a cinch. Basically you just drain the coolant, remove the timing belt and unbolt the water pump. You may also have to wedge the engine over just a bit to give the pump clearance to come out.
'98 S70 GLT
